Engine Drivetrain 2nd Gen S Stuck Piston Ring Scenario
Discussion in 'Tuning and Performance' started by genik, Apr 5, 2014.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    The car is a 2008 R56S, no modifications made! The pictures on #19 were taken that day that oil was sprayed on the motor!
  2. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    Your pics show oil near the timing chain tensioner --- a common source for oil leaks. A whole lot cheaper to fix. Maybe a bit painful to get at, but it can be done.
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    Thanx but Timing Tensioner was not loose! :)
  4. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    All I can suggest then, is to take things apart to find out where the oil is coming from. With luck, the solution will be obvious, and easy --- loose valve cover screws? None of the hoses in that area should have oil in them, so a broken / loose hose connection indicates a bigger problem.
  5. DneprDave
    The timing chain tensioner is right under that corner of the engine, best to check if it is tight. Torque it to 48 ft-lbs.
    Dave
  6. genik
    genik Member
    Feb 20, 2012
    402
    19
    Thanx Dave, chain tensioner was already checked (was not loose) and tightened! Even so, do you think all this oil could of come out of there?
