1st Gen R53 Cooper S Supercharged vs Turbo
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by fastrack1, Dec 1, 2011.
  1. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    #61 oldvet53, Nov 27, 2012
    That is what I like about the Supercharged MINI. The power and torque is linear from 2000-2500 all the way to redline. Despite the powersitic loss the power comes on immediately and doesn't have to wait for the turbo to spool up, the Supercharger comes on immediately as the R.P.M. increases in a linear fashion. In the old world of high H.P. Drag racers the Supercharger on that American V8 at the Drag strip is still King. How many Turbocharged Funny Cars are there in the winners circle?:Thumbsup:
  2. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    The Forge POV and a CAI fix a lot of those peaks and the fall off of torque. I was pretty surprised how much they helped, actually. :Thumbsup:
  3. DneprDave
    Our tiny turbocharger spools up so fast, you don't notice any lag. What many people think is turbo lag is the dead spot at the beginning the drive by wire throttle pedal's travel.
    Dave
  4. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    The 6200 rpm redline is what really stinks. I would love to have 8200-8500rpm redline on my car :biggrin5:
    ^ Couldn't that red-line be changed by a tuner?
    The turbo on the prince engine doesn't seem to have lag to me. Not like the one on our Subaru did. The small turbo spools fast, but seems to run out of breath at higher rpm. Just my .02. I'd be glad to do more in depth testing if someone would loan me their R56 turbo for a couple of weeks. :wink:
  6. Jan
    Jan Well-Known Member
    377
    382
    not going to happen without some major help with the valve train
  7. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    Redline is dictated by, among other items, valve inertia. In order to increase redline you need to reduce reciprocating valve train mass...springs, valves... etc. This is necessary to reduce valve float. And it's not simply a matter of increasing the stiffness of the valve springs. Increasing the spring rate has the downside of increasing cam wear.
    On my old rally car we used valve float as a rev-limiter. Worked well too. :smilewinkgrin:
  9. Dave.0
    This is why I went with a track tested and proven CNC BVH. All of these things have been thought of and addressed.
  10. DneprDave
    Whatsa CNC BVH?:eek:
    Dave
  11. Dave.0
    Computer numerical control (CNC) machine tools have revolutionized the machining processes and they are used to make Big Valve cylinder Heads by some vendors.
    (cough RMW cough) This means quality control is very high and every unit, in this case big valve cylinder head is milled to the same spec time after time.
    Other hand made heads can not touch the quality of a CNC machined head.
  12. ScottinBend
    Not true.....CNC allows consistency not necessarily quality.
  13. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    A CNC is only as good as the programer and operator, however that equipment if used properly will give repeatable results time after time. And a beter quality in the long run, I ran a CNC when I was making aircraft alternators with Bishop Aviation.
  14. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Like any tool, it depends on who is using it.
    ^^^ You've got that right.
  16. countryboyshane
    Jul 23, 2009
    202
    Diesel Engineering
    Understood. I don't think the Prince cylinder head components are up to the task for the redline I would like. Besides the cylinder head components need to be entirely reworked for a higher max engine speed, the next obstacle would be the restriction of the small turbo past 6K rpm. I just don't have thousands to blow on experimenting with crap like this. That is a true test, tune, and burn up cash task.
    I can say that I had the chance to compare my R56 experience to the R53 at Grattan Raceway last year. I got a ride in my buddy Roger's '04 R53 JCW and absolutely envied how he could wring the engine out and not have to shift as much. My tuned R56 had great gusto out of the corners but I had to shift from 3rd-4th on almost all my accelerations to the next corner where he could just hold that baby out in the same gear. A little more footwork on my part is no problem, but I think a driver that isn't good at heel-toe can get irritated with. Oh yea, that supercharger whine at 8200rpm is FANTASTIMUNDO!!!!
  17. CHKMINI
    CBS, keep in mind that the '04 transmission had a long second gear where your R56 doesn't. That may be some of the difference. Just sayin....
  18. mrntd
    Turbos aren't infinite because to get the fast spool up you have a low volume (small) turbo. At higher rpms the turbo can't handle the volume of air and the rest gets shoved through the bypass valve. That's all the mfgs have been and are working on variable volume turbos. The twin scroll is one good simple method. Honda has a nice one that uses a flap that allows more volume as the rpms go up. Chrysler had vanes that moved changing the volume in the 80s.
    Now after that I have to say I have been driving a 320hp turbo car for the last 7 years and drove the R56. But after driving my new R53....OMG:drool:crazy:. The power right at throttle tip in is unbelievable.
    Now where is my "WHINE is better than whoosh" badge? I'm sold
  19. Jason Montague
    :cornut: Thanks mrntd. This is why I love MA. I learn something new every day in an informative and polite manner. Again,thanks. If I had a 'whine' badge, I'd send it to you.:Thumbsup:
  20. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    Many auto makers have looked into using multiple small turbos so that spool up is fast and yet by using twin or triple turbos you don't run out of volume. In fact the turbos can be staggered so as to provide a very wide operating range.
    Many manufacturers have dabbled with variable vane or variable wall devices to accomplish the wide operate range in a single design. I'm actually a centrifugal compressor designer and have developed a few VGD's (variable geometry diffuser) for specifically that purpose.
    I am by no means an expert but Porsche and Mercedes have both referenced one of my patents. So when it comes positive displacement (superchargers) or centrifugal designs....I must admit to being a bit biased.
