1st Gen R53 Cooper S Supercharger help? :D
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by TimmyTurner, Aug 8, 2015.
  1. TimmyTurner
    TimmyTurner New Member
    Aug 6, 2015
    16
    Las Vegas
    UPDATE. I put the car up on some jack stands and took the front right wheel off. There is a definite wirring/ticking from the idler pulley. While I'm in there I'm going to replace the timing chain tensioner just because. Hopefully that fixes it.
  2. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    I replace belt, tensioner and idler pulley every year. Basic R53 rule to live by if you don't want any surprises.
  3. TimmyTurner
    Aug 6, 2015
    16
    Las Vegas
    If this doesn't fix the whirring/rattling thing i probably have bigger problems. :frown5:
  4. ZippyNH
    Might be a bit aggressive....
    I did my belt yearly...but my tensioner was 10 years old...had the factory one and 100,000 miles when I sold it...maybe I was lucky...but just monitored it...was fine. Things are good till they fail.....strut was fine and spring good, bearings fine...so I kept mine original OEM...
    Sure...I did not track my car, but IMO you should get 40,000+ miles from a tensioner minimum....
  5. BlimeyCabrio
    I've been through a whole pile of tensioners. I've had them fail in as little as a year. Usually it' the bushings that fail, then the thing pretty much rattles itself to death.
  6. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    well, the one I took off was original, 90k miles, and the belt slipped when just looking at the throttle (belt had been replaced 3 times).
    My logic on all this is: a lot of stuff on this car breaks at an alarming rate, so fix it before it spoils your appetite to keep driving this thing. I come from 20+ years of Toyota ownership, so my reliability meter has a slightly different scale to it than what others may consider normal. But I love the car, so I keep throwing parts at it to keep it as close to reliable as feasible.
    Thing is, all these maintenance parts I regularly swap out before they fail amount to less cost than a single monthly payment on a 2015 Mini.
  7. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    Check also: Alternator. They have an annoying habit of going bad at 70-90kmiles. Daughter's alt actually cracked the case nearly in half when it failed - sounded like a supercharger rattle but was the alt. And if you're getting at the s/c, be sure to change out the alt brushes as well, $11 part...
