SuperTurbo Mini Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by works4me, Dec 15, 2009.
  1. Chase
    Chase New Member
    this is one of my absolute favorite mini builds. I followed it on NAM for along time. Im glad that you posted it over here. Seriously an inspiration for me. I just took my car off of daily driver status a few weeks ago, so it will be dedicated to the track as soon as i am out of school
  2. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Aero update
    I was going to wait on my next update till I had everything mounted, but I realized that it might be better to explain my logic before you see the final product. Remember I'm going for *function* here, not aesthetics....really...
    First, I will remind you about some early analysis I did about aerodynamic improvements. A couple of years ago I had a splitter on the front - mainly for aesthetics. However I noticed that although it was not really functional (i.e. you couldn't properly adjust the angle or alignment), it did have a positive impact on high-speed stability.
    Moreover, given the fact that most of the weight reduction has been behind the center of gravity, I knew I had to compensate for the added front downforce with a rear wing that I could similarly adjust - both in angle & height. Moreover, I knew that by a proper placement of the rear wing I could also also reduce the drag on the rear end.
    However it is difficult to balance both goals in a single wing element. So my idea is to use a double element rear wing. Here is a link to a simple CFD simulation I ran looking at the effects of a double element rear wing:
    YouTube - lciscon's Channel
    I was able to get both the splitter and rear wing fabricated by APR Performance. They produce real functional racing elements & were able to make customizations based upon my requests (e.g. making the rear wing 1' narrower than normal).
    Right now I'll focus on the mounting of the splitter - the wing will have to wait for a future update. The splitter arrived about a week ago:
    I wanted to mount it in such a way as to allow the bumper to "float". By building a simple aluminum bracket, I was able to create a solid structure to mount it to that was also weak enough to bend/flex if I hit something:
    The bumper will slide in above this bracket. My next step is to fabricate/assemble/mount the front support rods. I'll post pics as I put them together.
    Ok, here's a sneak peek at the rear wing sitting on the floor:
    And wait till you see how I'm going to mount it.... :D
  3. BThayer23
    Was that a fluid dynamics analysis or was that you playing "The Italian Job" on the Atari? :D
    Wicked cool. Are you going to slot the holes on the splitter bracket or are those non-adjustable?
  4. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Yes, I'm going to slot them a bit. I may also add some additional cross bracing to the bracket...I haven't decided yet...
    Right now I'm trying to figure out better front support rods. I'd like to have somthing that has a bit of very stiff spring "give" to them.
  5. Mike
    Mike New Member
    Very interesting stuff, thanks for keeping us in the know.
  6. ScottinBend
    Again thanks for the updates as I love watching the progress.
    Are you going to be using any kind of rear diffuser?
    GP-type under body panels?
  7. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I'd like to. First things first.
  8. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
  9. Mike
    Mike New Member
    Now that's fun to watch!
    Holy crap! I'd love to know what factors/readings the control of that thing is based on. Very cool.
  11. PGT
    PGT Wheel Whore
    Leesburg VA
    read more here - the GT3 RS at the bottom is my buddy's. He's got one on his car....he's a distributor for them last I checked.
    From what he told me....it uses accelerometers to measure g-loads and then runs the flaps accordingly. They have dual flap, single and fixed.
  12. PGT
    PGT Wheel Whore
    Leesburg VA
  13. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    It's definitely interesting. Although it is a bit surprising that the G/G plots of the three tests are so similar:
    If anything the Red test might have a bit more in the upper left quadrant...but the Blue (i.e. fixed wing) test seems to have better coverage than the Black.
    One problem is that to be most effective the system needs to anticipate what's coming up before it happens. By the time it senses accelerometer changes, it's too late to get the bulk of the benefit.
    Maybe if it tracked the driver's head motion, then it could anticipate....hmmm.....
  14. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Subscribed and admiring.:Thumbsup:
  15. PGT
    PGT Wheel Whore
    Leesburg VA
    sup Eric!
  16. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Quick point of clarification/information:
    The splitter was not a stock APR splitter. They will make a custom one if you send them an outline of the bumper. I chose to go with a customer splitter because I wanted it to extend below the bumper instead of just connecting to it.
  17. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Design of bracket to mount rear wing
    Here's the design I've come up with for the bracket to mount the rear wing:
    The next question you'll have is how does this connect to the rear hatch...good question! You'll just have to wait & see :D
  18. BThayer23
    #58 BThayer23, Jan 26, 2010
    Is it gonna look like an old Fiat Abarth?
    ... (edit: couldn't find a pic)
  19. Deviant
    Deviant Banned
    Student
    Southern IL
    Reading the back-story why not take another inspiration from Chaparral and create a manual override for the wing so that when entering a turn where you'll need downforce, you can press what would essentially be a momentary switch on the dead pedal to go to a preset downforce level. This would be tricky on most standard transmission but with so many paddle shifts these days it would have a real benefit to them.
  20. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Wow crazy build :cornut: Not being a naysayer here, but why didn't you just go straight turbo only? Seems the twincharge was always hard to get tuned, but you seem to have that under control :Thumbsup:
