SuperTurbo Mini Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by works4me, Dec 15, 2009.
  1. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I certainly hope not!
    This what you are looking for?
  3. ScottinBend
    Wouldn't the diffuser have an effect on the design of the rear wing?
  4. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Very valid question that has come up a few times before. The long answer is this:
    Looking at all the various Mini mods, the general impression I get is that the people who have Turbos try very hard to get them to behave like Superchargers, and the ones with Superchargers try very hard to get them to behave like Turbos.
    Going back to the basic idea of forced induction, I understand and generally agree with the belief that Turbos are more "efficient" power generators than Superchargers. But that comes at a price: the standard variations of boost/vacuum in a track race make it difficult to design a turbo-only system that both reacts quickly and provides peak power under all circumstances. Combining the supercharger with the turbo opens up a whole new world of potential controls & optimizations.
    In a way it's easier to think of the Supercharger as a "pre-compressor" for the Turbo rather than a source of power for the engine itself. At a minimum it ensures a more even air flow when transitioning from vacuum to boost. I am *amazed* at how well the engine reacts to smooth transitions of fuel & timing in the tuning....regardless of boost & throttle variations. There are absolutely no dead-zones (that I'm aware of).
    As I've mentioned before, I think the fundamental challenges with combining the two are mainly around 1) the potential for interactions between the two systems (e.g. one fighting/starving the other) and 2) making the computer understand the different behavior of the system vs. a normal forced induction system. I think I have a very good handle on 1), and I'm definitely making good progress on 2). I must admit being able to control every aspect of the tuning under all conditions definitely helps :)
    Anyways, that's my thought process....feel free to disagree. I'm used to being "way out there" vs. the norm.
    p.s. The short answer is:
    That would be too easy! I never do anything the easy way....:D
  5. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #65 works4me, Jan 26, 2010
    Yes, it would help the downforce & thus the rear wing would not need to produce as much (and thus could be smaller). So in a perfect world it would be best to implement both at the same time. But I don't have the time or money right now to do everything at once.
    Each surface of the wing is adjustable. Moreover the design of the bracket allows a relatively easy re-adjustment of the overall position of the wing in the air flow. Once I add a diffuser I'll probably adjust both settings appropriately to re-balance the car.
    BTW one of the next things I want to set up are linear sensors attached to the suspension to precisely measure both downforce & overall suspension behavior. I can feed that directly into the MoteC/AIM & it will perform an analysis in real time....
  6. ScottinBend
  7. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Great answer :Thumbsup:Thanks for the info. That all makes good sense to me. Keep up the updates. BTW, what classes are you going to be racing in?
  8. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #68 works4me, Jul 11, 2010
    Latest mods & picture repost
    I haven't had time to post an update lately. Couple of things I've been working on:
    First, I had an issue with the turbo starting to leak oil. Upon investigation I found that the turbo was heat spiking, causing it to wear prematurely. It appears that this is pretty common when you track after-market turbos that don't have water cooling.
    So I decided to switch to water-cooling. You can order the turbo casing with or without the water coolant connectors. It's not really that difficult. You split off the tubes from the main line; they enter/exit 90 degress from the oil connections. You can see the red & blue connectors on the sides of the turbo in the picture below:
    The trickiest part was figuring out how to attach the braided lines into the existing coolant hoses...I finally found a reduction fitting that works well. And part of the tubing rises & falls right at the level of the overflow tank. So I adapted a gas sampling connector to act as a bleeder port. It works perfectly.
    The other issue I've had is that the ignition coil is too close to the turbo (see picture above). The connector & parts of the casing are beginning to melt. And my attempts to shield it have just made it worse by blocking the air flow around the turbo.
    I've wanted to switch to one-coil-per-plug to provide more individual control of each cylinder anyways. This also solves the heat problem by moving the coils far away from the heat source. I looked into changing to coil-on-plug, but I could not find ones small enough to fit in the R53's spark plug tubes. However Motec mates a coil-near-plug variant:
    I purchased these & struggled with how to mount them in the Mini's very cramped engine bay. I finally came up with a simple but effective mounting scheme tying them together with small strips of aluminum:
    Because I don't have the top-mounted intercooler, this *just* fits between the head and injectors and attaches with a small bracket to the header bolts:
    Here's a picture of it mid-way through wiring them up:
    And here's what it looks like with all the wiring:
    And finally everything together:
    This has not only moved all the wiring away from the turbo, but it has opened up a better air path back to the turbo:
    And I'm thinking of mounting a curved metal sheet where the coil used to be to help direct the air flow between the valve cover & the turbo.
    I have to re-run the ignition & injector tests, change the ignition settings in the ECU, and then I'll give an update on if I notice any change to the performance...
    On a seperate note, I noticed the pictures of my modifications to the front splitter mount were lost during the big outage. I've added a couple back to my gallery:
    As always, input is welcome!
  9. BThayer23
    Um, wow. Is there anything left on that engine that you haven't re-engineered? Other than the oil fill cap, that is. :D
    Are all turbos water cooled? I thought some of the Audis cooled the oil somehow. Have you looked at the impact on water temps of the extra loop?
    Did you have to rebuild the turbo or was the wear still within spec?
  10. Paul Webster
    Paul Webster New Member
    Jul 2, 2009
    78
    31
    Nice job on the ign coils looks OEM
  11. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I'm not sure if *all* factory turbos are water cooled, but many are. OEM systems also have the advantage of being correctly designed in to the overall airflow of the engine bay....
    I also considered adding a cooldown timer of some sort, but I'm not sure if that would have solved the problem on the track. And I'm not sure it's appropriate for a racecar.
    So far the impact on the water temps seems minimal.
    Yes, I did have to have the turbo rebuilt.
    And funny you should mention the oil fill cap. It rubs a bit on the air intake when you take it off. I'm considering switching to a smaller metal cap if I can find (or fabricate) one.... :D
  12. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Thanks!
  13. putterfarm
    putterfarm New Member
    May 18, 2009
    299
    Bum.
    Pittsfield, Pa.
    :Thumbsup:
    I'm completely impressed :D. The coil fix is great :cool: A lot of thought and fabrication on your part. A labor of love and not hair pulling I hope.
    What are you planning to eliminate engine bay hot air intake with the air filter where it is ?
    Mark
  14. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    All I can say is WOW!
  15. Rally
    Rally New Member
    50
    Ohio
    It'd be great to see the splitter turnbuckles replaced with pneumatics for cockpit adjustments :lol:
    Awesome work as always:Thumbsup:
  16. Minidave
    You touched on using a timer, that's really the right way to do it, your heat spike happens when the cooling stops because the engine isn't running - the same thing will happen with the water, the temp spike will simply boil it off and you'll have the same situation. If you do like the factory does and run a tiny electric pump on a timer for a few minutes after shutdonw - that will save it.....
    The alternative is to simply let the engine idle and cool the turbo, but I'm not sure just how cool it will get since you're still running hot exhaust gasses thru it. Complete turbo timer kits are available in the aftermarket and I don't think they're expensive.
  17. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Actually in this system the water cooling works via convection when the engine turns off. The turbo manufacturer does not recommend adding a water pump because it *reduces* the heat dissipation effect.
    Regardless I am keeping an eye on it & I have checked the water temp in the data log for spikes indicating boiling. I have not seen anything so far....
    The problem with any kind of timer is that generally when you turn the engine off on a track car they want it *off*. Things staying on is frowned upon...
  18. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #78 works4me, Jul 12, 2010
    My original idea was to fabricate a new air box that fitted around the filter and draws in air similar to the factory air box, but I haven't had a chance to do that yet. Now that I understand better the airflow around the vents directly under the windshield (or lack thereof), I'm not sure that's the best approach anyways.
    I now have air temp sensors in four locations: directly in the front air path (before entering the engine compartment), inside the engine compartment itself (near the filter), in the intake before the supercharger (but after the turbo), and after the intercooler. I'm planning on gathering more data from those under varying conditions to better understand the behavior of the overall system & then figure out the best approach....
    In the mean time it seems to be working well where it is.
  19. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Funny you should mention that...ok, not really (for now :D )
    ...but did I mention the aerodynamic dimples I'm adding?
  20. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    why mess with air? Pivots and a single electric linear actuator would do the job nicely. put a linkage on it and you could get away with a tiny one.
