SuperTurbo Mini Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by works4me, Dec 15, 2009.
  1. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Hmmm...
  2. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
  3. Rally
    Rally New Member
    50
    Ohio
    With air you could have air jacks as well. :arf:
    Honestly, I'm not sure why I typed "pneumatics"...I was envisioning linear actuators in my head when I made the post:crazy:
  4. PGT
    PGT Wheel Whore
    Leesburg VA
    :lol: air jacks are cool!
  5. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I must admit I've strongly considered adding air jacks....but there's several items higher on the priority list (e.g. molded plexiglass quarter panels with air intakes).
  6. beaner
    beaner New Member
    44
    i'm with you here. about $3k for a nice air jack setup. there are a lot of other places to spend that much $$$.
    nice build!
  7. putterfarm
    putterfarm New Member
    May 18, 2009
    299
    Bum.
    Pittsfield, Pa.
    :D
    Answering my own question is that once you're above 30/35 mph you're getting ambient air temps. This is what my research has given me :cornut:
    Mark
  8. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #88 works4me, Jul 30, 2010
    Update - purrs like a kitten!
    Ok, the car is running like a dream now....but I did have to fix two (of my) stupid mistakes first:
    My first Homer-esque mistake I discovered immediately when I went to run the ignition tests with the ECU. I hooked up a spark tester to ignition output 1/cylinder1, told the ECU to fire the spark (2400 RPM @ 6ms dwell) and it worked great the first time!!! Same thing with output2/cylinder2, output3/cylinder3, output4/cylinder4!!..... dope! They're supposed to be wired in firing order!! Sigh. Check the book...no, I can't tell the ECU to change the firing order. Fortunately I just had to rearrange one control wire for 2,3 & 4...sorted!
    Ok now everything works great! Great spark, everything in the right order, injectors running great, etc. etc. Finished reassembling everything, pushed the car out into the driveway, fire extinguisher handy, turn everything on, push the button - car turns over fine....but will not start. Nada. zip.
    Hmmm....well, I know the ignition & injectors are working OK. Let's pull out a spark plug & check the spark - perfect! (actually the best I've ever seen it). Battery low? Ok charge it...no change. I was running a bit rich last time I started it, maybe I'm flooding it. Trying cutting fuel by 10%, 20%, 30%...nope. Ok, add fuel by 10%, 20%...nada. Tweak timing...zilch. Sudden fear: maybe I left a rag in the air intake!!! Frantic disassembly...no, nothing there...ack!! Bad fuel? Worked last time I was running it & haven't added fuel since then...rogue settings value change in the ECU? (it's happened before)...methodical search...nope. Major frustration.
    As is often the case when I let my brain work on a problem in the background (i.e. when the silly conscious part is asleep) it quickly comes up with the solution. And as I was driving to work the nextday it explained it to me:
    As I've mentioned before in a 4-cylinder, wasted spark engine there are two equally correct timing points that are separated by 360 degrees. Setting the GRIP to either of these two values will work equally well. However now that I have one-coil-per-plug, this is no longer the case.
    I was 99% positive I had the correct value for the GRIP, but it's easy enough to check. The minute I got home from work, I pulled out the computer, changed one entry in the settings, flipped the switch...and it purred to life! Success!
    My impression thus far is that the spark with these coils is amazing. It may be my imagination, but the spark is far more intense than I remember it being before. Just as an example, when I was running the initial tests I moved one spark plug wire from coil-to-coil. At one point I forgot to switch to the next coil. When I started the test, the spark jumped from center post of the previous coil to the closest metal contact point..over 1.5" away!
    On a separate note, I also painted the valve cover with a ceramic-based high temp paint to help protect it (a bit) from the heat.
    Here's an updated picture of the whole engine bay:
    I also built & mounted a prototype "air scoop" to try to force more air down between the turbo & valve cover. I'll make a prettier version after I verify this is really helping:
    And just in case you're curious, here's a picture of my work area:
    More testing this weekend...
  9. ScottinBend
    Fantastic work! Love this build thread.
    Still a twin-charge......right?
  10. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    As indicated by the plumbing that is def still a twin-charge!
  11. ScottinBend
    I assumed as much, but just wanted to verify it.
  12. Jan
    Jan Well-Known Member
    377
    382
    so what are your inlet temps with the front mount?
    thanks
  13. mini_racer
    Engr Manager
    Better yet, what are the IAT deltas between that front mount and the OEM IC ?
  14. jason@MynesTuned
    jason@MynesTuned New Member
    Jan 10, 2010
    39
    You are using MoTeC right? The CRIP is 78 degrees before TDC. The 60-2 trigger wheel 13 teeth after the gap, each tooth is 6 crank degrees.
  15. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I recently rearranged & recalibrated the temp sensors & am planning on gathering updated logs on that on my next run. I have one stock air sensor & two from Motec & I didn't trust the data from the stock sensor - so I swapped the positions around. I'll post the raw data & my thoughts on it as soon as I have it.
  16. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Before I had the GRS front-mount IC I had a GRS top-mount. So I can't exactly compare it with stock. However I do happen to have a stock IC laying around. So I'll take that to the next event & do one run with it just to compare to the others....just for fun...
  17. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Yeah, I meant CRIP not GRIP (different acronym from my day job).
    Interestingly those are the #s I was using before. I had to change the CRIP to 78+360=438 for it to work. Hmmm....
  18. jason@MynesTuned
    Jan 10, 2010
    39
    Oh okay, that's correct if you are using the hundred series ecu, forgot which one you are using.. it's the M400 right? For the M4 or M48 it's just 78. :Thumbsup:
  19. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Ah OK. Yes, I have the M400. Thanks!!!
    -larry
  20. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    My new ring tone!!
    I moved the car onto ramps yesterday & thought I'd try making a quick audio recording from my phone (attached). Just keep in mind that I'm basically just idling & the waste gate is closed...so this is the car being "quiet". Also the engine is running way too rich here; I've got to adjust the temp compensation down a bit more.
    When I make track recordings I have to turn the gain down so much you usually don't hear this part....That's one of the main reasons I'm finally planning on merging the waste gate output into the main exhaust & add a repack-able racing muffler.
    I'll post more info & updates this weekend...
