SuperTurbo Mini Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by works4me, Dec 15, 2009.
  1. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    New muffler & next project
    Wohoo! My muffler arrived yesterday!
    For something that's going under the car that noone will ever see this thing is a piece of *art*. Because it is repackable, you need to be able to take the muffler on & off. So I had them weld two tabs onto a metal band clamp. I can then bolt this onto braces attached to the car:
    I went with the perforated steel mesh option. It's the most resistant to heat:
    A good excuse to use the new lift.... :D
    And just FYI here's a sneak peak at my next project:
  2. Metalman
    Very nice muffler......
    Is that the new modular design from Coast Fabrication, Inc.?
  3. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    It is a Coast muffler & it is re-packable (see the small screws at one end). But it isn't their new "two stage" model. I'm not really aiming for huge muffling out of this...
  4. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    Changing settings mid-track day! I have enough trouble adjusting pressures correctly between sessions, everything is so rushed :crazy: How quick is "talking" to the Motec?
    Think I just need the right tools, like a lift to swap brake pads and an air compressor... this threads makes my x-mas list longer and longer... :cornut: ...maybe a vaccum pump for carbon pieces too :D
  5. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Re-uploading to the Motec just takes a couple of seconds. Having a real USB link to the computer makes a *huge* difference. More importantly I can get live data from it continuously.
    That reminds me I need to take a picture of my new in-car laptop mount...
  6. BThayer23
    Does it look anything like this? :lol::lol:
    [ame="http://www.amazon.com/AutoExec-WM-01-Wheelmate-Steering-Wheel/dp/B000IZGIA8"]Amazon.com: AutoExec - WM-01 - Wheelmate Steering Wheel Desk Tray - Gray -: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41m23Y36VAL.@@AMEPARAM@@41m23Y36VAL[/ame]
  7. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Actually it looks like this (forgive the grainly low-light image):
    It's positioned such that I can get to the keyboard even while strapped in, yet it doesn't block any of the center controls.
    The mount is light, but sturdy. It bolts to an attachment I made on the right downtube (with a steel backing). And it's designed so that I can take it out in about 10 seconds if I want to run with a passenger.
  8. Metalman
    Ram Mounts also makes some very nice "quick disconnect" laptop supports. Seems like all their offerings are well made.
  9. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #129 works4me, Nov 5, 2010
    Valve Cover Mod
    So moving the coils definitely fixed the issue of melting of wires. And it helped reduce the melting on the valve cover considerably. But there's still a small amount of melting regardless. I'm sure I could run a couple of weekends before it gets too bad, but the risk vs. reward is considerable.
    So I've decided to solve the problem the right way, i.e. install an Aluminum valve cover. Since there are no Aluminum valve covers for Minis (that I can find), I'm having to design one myself. Because the shape varies in all dimensions, it's best to have it machined out of a solid block vs. welded. Below are some pictures of my in-progress design.
    The trickiest part of the design is the baffles for the PCV. I could leave the space & try to fabricate my own baffle system, but that would be complicated & potentially dangerous (if something came loose & fell down). Instead, I've lowered the top of the cover to leave room for an external PCV system attached through a hole. This considerably simplifies the overall design & gives me even more airflow back to the turbo.
    One slight problem: the software I've been using is somewhat limited. Finishing the remaining portions of the design (e.g. rounding the remaining edges, cutting the groove for the seal, cleaning up some of the corners & faces) would be extremely tedious & error-prone. So I'm going to try switching to a different tool to do the rest.
    The x-ray render mode is very useful for seeing flaws in the walls and intersections:
    That's my new desktop background image. :D
    As always, comments & inputs are welcome!
  10. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    An experiment
    Here's a link to an interactive 3D version of the model. You'll have to install the plugin - it's from Dassaut Systems (makers of some of the top MCAD software).
    http://www.3dvia.com/models/03E62A390B1D2F01
  11. beaner
    beaner New Member
    44
    great, innovative stuff again. i always look forward you your updates on this thread.
  12. BThayer23
    Which CAD program are you using? Time to step up to SolidWorks or ProE?
    Also, I don't know much about manufacturing aluminum, but would it be easier to just make a mold of the plastic cover and cast it in aluminum?
    Between reading this thread and dpcars.net, I'm about to sell my worldly possessions and build a custom race car.
  13. Metalman
    Yep.....
    I use a local fellow here in Columbus to do a special cast part in aluminum. If you can make the "pattern" yourself out of wood, it's dirt cheap. He uses a sand cast process. I'd be more than happy to run your drawing over to him and have him quote the part to you.
  14. beaner
    beaner New Member
    44
    what temps are you seeing at the valve cover? i have thought about making one from pre-preg cf, but i don't know if it will handle the heat.
  15. BThayer23
    I'd think it would be way easier to cast any internal PCV baffles rather than try to machine them or come up with an external solution. Just my 0.02.
  16. Metalman
    The biggest problem I've had with my sand casting supplier has been some small issues with porosity. My parts are quite a bit thicker at around 1-1/4". But he has always taken them back, re-melted the aluminum and made the part over. The biggest single cost has been making the template. He has a guy that makes the templates if need be, but they really aren't complicated. I'll take some pictures of a couple of parts I get made now and post them up.:D
  17. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #137 works4me, Nov 5, 2010
    I considered doing a casting from a pattern, but decided against it for various reasons:
    1. I knew the design would have to be modified no matter what, so I couldn't use the original as an exact model.
    2. Given the shape, producing a good physical pattern would take a very large amount of effort.
    3. Also given the shape I was slightly worried (perhaps incorrectly) about the potential of leaks from imperfections in the moulded part & mating surfaces.
    One alternative I thought of for producing the pattern was to use software to stich photos of the cover into a 3d model & then print the the prototype from that. But that ended up being even more work due to cleanup needed in the model & moulds.
    In the end this was really the quickest & easiest approach. I'll probably spend a total of 10 hours on the model - most of that because I'm learning the software at the same time. I can then give it to a shop with a CNC machine & they can quickly produce a clean, precise part. Moreover it's easily repeatable if I need another one in the future.
  18. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Err, I don't quite have enough projects like this to justify the expense *yet*....
  19. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    It's a bit difficult to measure at the exact point-of-failure. My best guess is at least 400 degrees continuously and close to 1000 degrees momentarily.
    Just to repeat: I get these spikes because the header+turbo flange sits less than 2" away from the valve cover at the closest point! A normal cover shouldn't see anywhere near these temps.
  20. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I definitely agree that machining or fabricating internal baffles would be difficult . It's possible to cast them, but my spider sense sais that it would take several tries to get it right.
    The external solution is trivial to implement, cheap, and 100% reliable. You can buy PCV valves in a baffled container off-the-shelf. All it needs is a hole about 1.25" dia. in the cover.
