SuperTurbo Mini Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by works4me, Dec 15, 2009.
  1. BThayer23
    Go with your spider sense!
  2. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Wohoo! over 5,000 thread views!!
    Ok maybe it's not a big deal for you guys, but it's the most viewed thread I've every had....
  3. Metalman
    Bump, Bump, Bumpty, Bump Bump........
    I want to see that C&C'd valve cover......
    Time for an update????
  4. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Been really busy at work & haven't had time to give updates...I'll try to put something together this week.
    In the mean time, here's a couple of pictures of my modification to the turbo downpipe to merge in the wastegate bypass smoothly back into the exhaust. I TIG welded the merge pipe on myself, and I cut off & welded on a new exhaust flange...it was a good excuse to learn how to weld. Next winter I have a goal to build a new downpipe with a better design all myself....but I'll need to practice a *lot* before that!!
    BTW, I've been cleaning out & organizing the garage to give myself a good metal workshop space. I still have to get a few things, but I'm making good progress (sorry they're a bit blurry):
    When I'm done I plan on posting some info on what/how I set it up...
  5. Metalman
    Nice.....
    I like your MaxJax lift... Nice man cave....
    One trick you might try is to cap both ends of the tubing (large rubber stoppers work well) with a small hole in both caps. Then gently feed a little Argon in one end (don't pressurize the tube) just enough that the tube stays filled with Argon (trickle feed) while you TIG weld. You will end up with very smooth welds inside the tube that won't need any dressing. Can't tell if the tubing is mild steel or stainless. If stainless, when you get the welds with that nice honey blond with the aqua blue highlights, you're on top of your game. Practice, practice, practice...:Thumbsup:
    Thanks for the up-date.....
  6. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Yeah, I've heard of that technique, but I haven't tried it yet. I assume you tap off of the argon tank for the feed. Where do you find rubber stoppers that big??
    Another person suggested fitting an aluminum tube inside that fits fairly snugly. It won't fuse to the weld & keeps the inside nice & smooth...
    I really should have taken pictures of the garage beforehand. I've thrown away a *lot* of junk to get it to this state.
  7. Metalman
    In your downpipe example, the easiest would be to just cap off from the flanged end with a plate and use the bolt holes for fastening.... the opposite end could be stuffed with a rag. Anything to simply hold the argon in the tube.
    I've used aluminum flat plate on the back of steel and stainless when welding. In the suggestion of the tight fitting aluminum tube within a tube, you may find it difficult removing the aluminum tube when you're finished because you've slight coined the two materials not as a welded bond but as a distorted interference fit.
    Large stoppers are used by plumbers to test leakdown pressure in plumbing circuits. Available in many sizes. Also science supply houses for large stoppers. Use anything that handles the nearby temperatures that will still hold the argon in the cavity. It doesn't need to be anything fancy. You don't need a perfect gas seal.
    Anyway, enough about welding, post up more on you project if you have time. I find it extremely interesting. :D
  8. Chase
    Chase New Member
    I love every update with this build. Your car is still a great inspiration to me.
    I am sending you a pm about some questions.
  9. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #149 works4me, Jun 5, 2011
    Thermal testing
    I realize that people are waiting on an update on my Aluminum valve cover. Unfortunately the local shop I'm working with has been backed up with "real" work with Oil firms & gov't projects, so it's take a bit longer than anticipated...
    In the mean time, even with the new Aluminum cover I still need to protect the back of it to reduce the heat transfer to the engine. I purchased some high-tech heat reflection foil that is supposed to reflect 96% of the radiant heat:
    But given the fact that the last protective material I put on the cover vaporized in a matter of minutes, I decided to first do a semi-quasi-scientific study on heat transfer to the cover with and without protection.
    For reference, the melting on the cover from the Turbo looks like this:
    To recreate the indirect heat of the turbo, I set up a propane torch approximately 1.5" from the cover. I placed a sheet of thin steel between them to convert the direct flame into a radiant source:
    I used an IR temp sensor capable of measuring up to 1400F to measure various points. With a moderate flame I was able to produce a radiant spot about the size of a quarter.
    This in turn heated the cover to about 300F at the closest point. At this temperature the cover began to melt in about 1 Minute & produced a melting pattern very similar to the one caused by the Turbo:
    I then tried re-running the test with a cover I had painted with a high-temp ceramic-embedded paint. This did seem to improve the behavior somewhat; it now took two minutes to get to the same level of melting:
    Next I tried a section covered with the Foil:
    I ran the torch for over three minutes this time and it showed absolutely no signs of melting. Furthermore, I tried to measure the inside temperature (a bit tricky) & I believe it stayed around 100F. Finally, in true Mythbusters fashion I decided to "crank things up a bit". I moved the torch a bit closer together & increased the flame on the torch:
    With this setup the cover temperature reached 500F and the metal sheet got to 800F. I let it sit like this for over a minute. I only stopped it because it looked like the torch was about to burn through the metal sheet.
    The end result looks like this:
    i.e.....nothing. No bubbling, distortions, discolorations or anything else. Color me impressed. It's definitely going on the car!!
    Next up: wiring in a second battery & an update on the valve cover:
  10. Nathan
    Yahoo. An update!
    So what is this stuff?
  11. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I could tell you, but then I'd have to...you know...:wink:
  12. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Oh all right, if you twist my arm:
    It's heat reflective tape similar to what they use in F1. But this version is considerably cheaper than the F1 version....on the other hand the F1 variant is 97% reflective vs. 96% for this one.
    Here's a link:
    Heat Reflective Tape NEW!
  13. jiminni
    jiminni Well-Known Member
    262
    Ca.
    #153 jiminni, Jun 5, 2011
    Wow....very cool testing there :Thumbsup: Just checked that link, a few guys here have purchased mufflers from those guys, Coast Fabrication, they are expensive but they are very nice :Thumbsup: I may have to go to one of their mufflers if my car eats another fiberglass resonator :( They have a muffler available with "scrubble" as the filler, very tough stuff, but again, very expensive too.
  14. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    Actually the mufflers aren't that expensive considering the lifespan (taking into account the repackability & quality of materials). I have the Stainless Steel Mesh filler. It's slightly heavier than the scrubble, but it's designed for absolute maximum endurance.
  15. TATTRAT
    TATTRAT Well-Known Member
    496
    399
    Executive Chef
    NoVA/DC
    Jesus, this is all just amazing! It's like something from NASA, a NASA for MINI!
    Love the build!
  16. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    I'm constantly amazed at the depth and variety of Engineering that goes into a car. There's an infinite amount you can learn & do...if you're not limited by what you (currently) know.
  17. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    #157 works4me, Jul 4, 2011
    Aluminum Valve Cover Update Part 1
    Ok, after significant delay, here's an update on my Aluminum valve cover project. A huge thanks to Voigt Machine Inc. here in Houston for their extensive help in taking my vague ideas and getting them to work.
    I simplified the design of the stock cover significantly - removing the built-in baffles and numerous extraneous curves & elements. I stuck with having a groove around the lip so that it uses the stock seal. And I found an off-the-shelf external valve cover vent with a built-in filter. It's a bit bulky but it works as a first cut.
    Voigt was able to make it work on the first try. Here is what it looks like:
    To seal around the spark plug tubes, I found an Aluminum baffle with inner and outer seals:
    By cutting off the top it forms a perfect seal. You can see one installed in the images.
    I have an old head I've used as a test block. Today I did a test install on the car to check all clearances. Here's what it looks like:
    The good news is that it all looks good. The only adjustments I need to make are to trim off a bit of the bracket I made for the ignition coils. And I need to trim the rubber around the spark plug boots to fit better into the (slightly smaller and deeper) hole. I should be able to finish this up next week & start it up.
    Now that I have a prototype, it's relatively easy to have more machined. Alternately, this could be used as a master for a cast version...
    Thanks again to Jim & Craig at Voigt. They are miracle workers!!
    More updates to come!
  18. ScottinBend
    Cool stuff as always!
    Where did you move the coolant/power steering tanks to?
  19. works4me
    works4me New Member
    Jul 19, 2009
    138
    11
    The coolant tank is visible as the welded aluminum tank on the far right on the 3rd to last picture. The power steering tank is underneath the air intake.
  20. ScottinBend
    Ahhhhh......so it's where the airbox used to be.
