2nd Gen R56 Cooper S Suspension decision.
Discussion in '2nd Generation: 2007+ R55 through R61' started by miniwop, Oct 13, 2012.
  1. jiminni
    jiminni Well-Known Member
    262
    Ca.
    After lowering in the rear, you WILL need to adjust the camber back there. Depending on the year of your car, later year rear control arms have a small amount of adjustment to them, not much though. After I installed springs on my car, 03, they lowered more than the TSW's, I had to use aftermarket arms. Since have gone to coil overs.
  2. miniwop
    miniwop New Member
    Oct 6, 2012
    25
    Thanks for the great offer but it seems a little much to drive all that way and back for an alignmet. thanks tho, you guys are very kind.
    You want to give it a few miles to settle before getting an alignment.
  4. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    #24 RussWK, Oct 21, 2012
    Rear Wheel well liner question. I have 18 X 8 rims with 215x40 tires. Stock springs with Koni FSDs. On hard bumps/dips rear tire hits plastic liner. What experience does anyone have to enlarge clearance, or other advice?
    2006 R52
  5. Dave.0
    I cut the tops out and used undercoating in the rear wheel wells.
    I also took off and trimmed back the plastic arches with a dremmel and flaired the rear quarters a little with a hammer and dolly.
    I have 215's with 5 mm spacers in the rear with KW V2's running low but not super low.
    Drive enough & they will clearance themselves. Wore holes through mine. Added a bit of undercoat in there too.
  7. Dave.0
    Yup I'd did this also to find the areas I needed to make "adjustments" too.
    That little bolt that holds the rear side marker light needed to be trimmer down a little also.
  8. Firebro17
    Mine is done as Dave describes in Post 25...
  9. RussWK
    Apr 1, 2011
    106
    61
    Thanks for the advice!
    --Russ
