Suspension Brakes Sway bar/anti-roll bar
Discussion in 'Tuning and Performance' started by Rangerx, Sep 18, 2014.
  1. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    I'd be happy to install it for you, but you'd spend a ton on gas to get the Bug Eater to my shop.
  2. Firebro17
    You're correct for the most part. Most of us will never experience the unreasonable sinter conditions you all do in the east and mid west. It all depends on where you hang your hat as to what the climate is like...
  3. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Yeah this seems like the more thoughtful thing to do .
    What kind of suspension did you put on your mini?
  4. Rangerx
    Rangerx New Member
    Jun 25, 2014
    So will that be good for the winters up here ?
    We get probably like 2 or 3 feet of snow sometimes at a time
  5. Stefanie
    Stefanie Well-Known Member
    May 8, 2014
    545
    804
    Sacramento, CA
    Koni sport shocks and Swift Spec-R springs, at the great advice of many of the helpful people here on MA. :)
  6. Dave.0
    It will be fine just as long as you lube the polly bushings via the fittings.
  7. rkw
    rkw Well-Known Member
    443
    H&R is based in Germany (including all of their manufacturing). They aren't blind to weather concerns.
  8. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Yeah stefanie they are very very hopeful :)
    Dave.O is that an initial lubing or a constant ?
  9. Dave.0
    ALASKA is really effing cold in the winter compared to Germany.
    I agree H&R does make some damn food parts.:Thumbsup:
  10. Rangerx
    Rangerx New Member
    Jun 25, 2014
    So just a initial lubing Dave.o
  11. Rangerx
    Rangerx New Member
    Jun 25, 2014
    So does any body thinking I'll have a problem with the suspension as with the dropping of it cause we have very bad road up here pots holes and uneven road would you guys still try and get after market or just stay with OEM
  12. MCS02
    You will have to watch the pot holes, but I would go aftermarket.
    Oh and maybe point that MINI south! :D
    Only you can make the call on if lowering your car is a good idea. Lowering your car will lose you suspension travel. My car is lowered about 1/2 inch & there are times I miss that 1/2 inch of ground clearance.
  14. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Well that's what I mean crashton lol I've never lower a vehicle but is there a way I can get aftermarket and keep the height I have now with my stock
    mGS02 I know I'm thinking about moving down maybe east coast lol
    If I lived where you do I wouldn't lower my bar, that's just me. Maybe wait until you move & then alter your cars suspension.
  16. BlimeyCabrio
    If it was me... I wouldn't lower a car in Alaska unless it was a summer-only driver.
  17. Rangerx
    Rangerx New Member
    Jun 25, 2014
    So what's a good suspension that doesn't lower a lot ?
    Nothing wrong with the stock one if you ask me. Once you wear it out change it. That's what I did with mine.
  19. Dave.0
    KW makes a great set of coil overs and you will be able to raise and loser your car to any height you want.
    You will even be able to go higher than stock for those crappy roads and snow.
    If you add a good set of snow tires your MINI will be unstoppable. :Thumbsup:
  20. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Yeah I'm thinking blizzak for the tires and thanks I'll check those coilovers out
