Suspension Brakes Sway bar/anti-roll bar
Discussion in 'Tuning and Performance' started by Rangerx, Sep 18, 2014.
  1. ZippyNH
    One issue with coilovers...they are not as tuff as the stock spring/strut setup...
    Be prepared for a failure...on smooth roads they do fine...but they tend to have PHYSICAL failures due to POTHOLES...remeber they are RACE BREED....and no potholes on a racetrack....
    The roads I drove on in Kenai/Soldonta area WERE pretty good when I lived up there...but the washboard gravel side streets and "breakup" might be an MAJOR issue if you lower. Good luck....
    Me I would stick with the stock height...maybe Koni FSD's, and spend the $$ on a set of extra rims....
    You can have some crazy fun with a near stock suspension and a bigger rear swaybar with good tires....heck...I bet 90% of drivers cannot use 100% of what their car can do....
    FYI they also use coil overs in off road rallying. :ihih:
    Also said you can dial them up (adj.) them to be soft and raise the car height with them. :idea:
    Shocks and Springs all only have one setting and I would never buy Koni FSD's.
    FSD stands for: F-ing Stupid Design :lol::devil:
    Koni makes good shocks but the FSD's are garbage.
    I'm not an expert on coil-overs or coil-unders & don't play one on M/A. That being said I just have to stick my .02 in here.
    Yes rally cars use quite sophisticated coil over set ups. I'd guess one corners worth would be worth more than my MINI. I don't think any off the shelf affordable coil-over is any where near tough enough for rough road use. One other thing is using a coil-over in the corroding winter conditions will make them un-adjustable in short order.
    OP paid someone $150 to fix a loose screw on his airbox. Don't think he's going to be under his MINI cleaning coil-overs to keep them adjustable. I may be wrong, but that is my take.
  4. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Haha yeah stupid **** 120 for a striped screw ..
  5. Dave.0
    #45 Dave.0, Sep 21, 2014
  6. Rangerx
    Rangerx New Member
    Jun 25, 2014
    Thanks I'll check it out
