Suspension Brakes Sway Bar End Links
Discussion in 'Tuning and Performance' started by leicaguy, Sep 22, 2010.
  1. minimark
    Doubt that they broke from one strong bind but from repetitive stress over time.....
  2. BThayer23
    It's a question of shear stress vs axial stress. The swaybar is subject to a twisting motion (torsion), which creates shear stress within the steel. The endlink has bushings on either end that isolate it from the bending moment, so it's only in tension or compression. A thin steel rod handles tension and compression better than torsion, as long as the forces don't reach the yield strength. And yes Mark, failure was probably due to metal fatigue.
    Makes me want to call up my parents and tell them that my college degree was actually useful. =)
  3. Metalman
    So is it safe to say, if you go larger than stock on the sway bar, go to heavier duty end links? Or does the stock end links have a large margin of safety built in?
  4. Onasled Racing
    Onasled Racing New Member
    Jul 19, 2010
    172
    Drop links do take a certain amount of non-linier (don't think that's the term I am looking for) forces. All has to do with the angle of the sway bar ends and why one needs to think about how many degrees out of perpendicular to the drop links they are running. Once the angle is out of 90* to the drop links, side forces start being applied. This actually causes a "progressive" rate in the sway bar.
    Anyway, the fronts are always undergoing non-linier forces and it's why they break
  5. maacodale
    maacodale Club Coordinator
    255
    Poquoson, VA
    Don't forget, the most important thing concering sway bar links is the heim joints. Those fail more often (and wear out more often) that the actual link, itself.
    On our Legends cars we'd replace heims at the start of each season and still would end up with 3 or 4 new heims by the end of the season.
  6. Onasled Racing
    Jul 19, 2010
    172
    Really...? What's up with that do you think? What do those things weigh, 1200 lbs? I know you guys race those things like every weekend so maybe it's just that.
  7. Mike S
    Mike S New Member
    Aug 18, 2009
    12
    Anybody know what the lengths of a slightly dropped suspension's end link should be?
    I'm installing the Powergrid ones, but I have misplaced my OEM ones. Car has been on jacks for half a year.
  8. Metalman
    I would have suggested you try the NM engineering end links, not much difference in price and seem to be much better than stock and being partially aluminum, will probably be lighter than the Powergrid. They make good stuff.
    I don't know the length of a "slightly" dropped MINI, but if you follow the instructions and keep the bar arms level, you'll be good.
    http://www.nm-eng.com/media/attachments/203_328856_ins.pdf
  9. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    Hi Mike,
    The OEM ones are 9.25" measured from the centre of the bolts (mine are sitting in the basement, so it was easy to measure).
    I believe you'll need to shorten them about the same amount as the car is lowered, so the swaybar is parallel to the ground when the car is sitting level on all 4 wheels.
    didn't see metalman's post. What are we all doing up so early on a Sunday?
  10. Metalman
    I'ma eatin a donut I missed out on yesterday with my MOM peeps......:D
  11. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    drinking coffee, measuring endlinks, wishing I had a donut.
  12. Metalman
    ^^^ There is this Canadian dude by the name of Tim something or other... Norton maybe.... Tim Norton's..... No that's not it, but I'm close.... Anyway he's been known to sell a few..... If you can't find him locally, stop by my place, I still have a few un-touched....:D
    On the 9.25", I'm guessing that's the rear end link length, the fronts are different....:Thumbsup:
  13. Mike S
    Mike S New Member
    Aug 18, 2009
    12
    Thank you so much! I forgot to mention, my car is a R53 and I didn't notice this was in a 2nd gen forum :( I wouldn't think there would be too big difference between the two seeing that some suspension parts are inter-changeable.
    Good point! grodenglaive, can you confirm if this is for the front or rear? :D
  14. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    oh yeah, that's for the rear, I just assumed you were doing the rear sway bar. The fronts are 11 and 3/4 btw.
    never did get that donut - if only there was a Jim Norton's nearby:ihih:
  15. Mike S
    Mike S New Member
    Aug 18, 2009
    12
    Thank you so much! If I'm ever stateside, I'll send one your way :donut1:
  16. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Lengthen the front drop link, shorten the rear. Start with 305mm center-to-center in the front for .5 - 1 inch lower. Shortening the front link will run the risk of contact with the driveshaft under full compression.
  17. Mike S
    Mike S New Member
    Aug 18, 2009
    12
    Thank you Keith!
