Brakes Wheels 1st Gen Tires Team Dynamics PR1
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by M^Cubed, May 23, 2010.
  1. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    #1 M^Cubed, May 23, 2010
    *UPDATE - FIXED* Team Dynamics PR1
    I have a curious question for TD PR1 owners or aficionados.
    Is the offset stamped into the wheel? I have the size and IIRC the weight cast into the wheel, but there seems to be some numbers stamped in also. They are hard to read on two, but one looks like the correct offset number while the other looks like a number that is not the offset that I purchased - this concerns me - this set of wheels is quite a bit twitchier on the road than my other two sets and also seems to pull to the right. They all look identical from a visual standpoint, but I have nothing to measure them with.
    Cheers
    You can measure the offset.
    Lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel.
  3. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
  4. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    I drove the car another day on these wheels and they are like a different animal from my LM's.
    They were recently balanced - they would have caught that they might be bent during that process?
    What I mean by "a different animal" is that they are a complete handful to keep the car going straight under acceleration. They use identical tires as my other set, but these just want to go all over when you accelerate. I know Camaro has driven it and thought the same thing.
    Can the light weight be causing this or is something wrong with them? (mis-matched size and or offset?)
    Partial throttle for passing causes the car to pull hard right and when you lift off throttle it "snaps" back straight. It sounds like a suspension problem, but it only happens with these wheels - which are the lightest and shortest I have.
    Rotate them around and see if the problem moves.
    Also, are these new tires?
  6. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    They are not new tires - they have over 5K on them I believe, great tread still though and even wear. I am going to rotate them because this is dangerous right now.
  7. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Alright - fronts swapped Left to Right.
    The car is still acting the same - the steering wheel goes left and the car goes right.
  8. FUEGO
    FUEGO Club Coordinator
    IT Geek
    DFW Texas
    Could be ball joints or a bad hub.
  9. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    The only other thing I can think of is that I power washed the underside of the car. I spray a good amount of excess lubricant off of the FCAB's. I wouldn't think the outside would affect it.
    I'm going to toss back on the other wheels and see if that changes anything.
  10. Metalman
    You might check to see if the entire power steering assembly is loose and or moving sideways in the rubber bushing mounts that attach to the front frame member? It sure doesn't sound like a safe situation.
  11. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Alright - I will check that too
  12. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Well, it turns out the issue was the two M12X1,5X60 bolts that attach the ball joint to the subframe had backed out enough to give me some cool dynamic steering.
    Everything was snugged back up and the car feels nice and solid again!
    Thanks to everyone who helped
