1st Gen R53 Cooper S Tensioner stop opinions?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by FERNO, Jun 6, 2009.
Which tensioner stop do you, or would you use?
Poll closed Jun 16, 2009.
  1. Alta
    2 vote(s)
    9.5%
  2. Detriot Tuned
    18 vote(s)
    85.7%
  3. GTT
    0 vote(s)
    0.0%
  4. Other
    1 vote(s)
    4.8%
  1. checkers
    checkers Well-Known Member
    Jun 11, 2009
    4,418
    1,002
    Modesto, Ca
    I have the GTT tuning stop. All I can tell you is I've had on troubles with it or the idler pulley bearing that I got from them. I also so have their adjustable cam gear. All their products are well made.
  2. bodinski
    bodinski New Member
    Jul 10, 2010
    12
    Lost my belt just before Christmas. Then the tensioner broke (!) when it wiped out my crank pulley. USE A STOP!!
    On an unrelated note, I got 'er back together 1-5-12, only to bust the oil pan (unseen debris?) on 1-12-12. Think I shut her off in time to save the motor.. When will the madness end?
  3. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    My DT stop came apart after ~5K miles, so I can't recommend that one.
  4. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    My DT stop did its job last july when my damper pulley died and ate my belt.
    I've had a DT stop on for the last 6 years installed by Chad himself. I've been careful to watch the belt & replace it before it jumps ship so it has not been tested in anger I guess. I do believe it will do its job if asked.
  6. agranger
    I had a DT in place for about 4 years and it wore in the middle and eventually broke (which I felt was a fair service life for the part). Unfortunately the end pulled out on the replacement unit. When I can get it off of the car, I hope to send it back.
    I'm sure Chad would make it right if someone sent him a busted DT stop.
  8. ZippyNH
    If i had to bet $$, i would think the failed ones are cheap imitations...possibly using an electrical connector, made of aluminium....or it might have been fastened so the connectors rubbed.
    The DT desgin is simple, quiet, and relilable, but easily copied to an inferior standard...
    I have a dt tuned tensioner....
  9. agranger
    Yep. I've heard great things about DT customer service and I'm sure Chad (or Way, as I purchased from WMW) would come through. I've just gotta get it off of the car first and it has been on my low priority list. I've also got some cool new ratcheting box end wrenches coming (a splurge of a gift purchased with a bunch of Christmas gift cards from Home Depot) which will make this a much easier job, so I'm waiting for them to arrive.
  10. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    Alta tensioner stop for me and my buds. We don't care about noise. :)
    Jeremy
  11. Sneedspeed
    Sneedspeed New Member
    Jul 16, 2009
    165
    56
    Racing cars
    Pfafftown NC
    We have never had a DT one fail but an Alta one did miss once and that was not good for the balancer. We only use the DT one here at the shop now
