Engine Drivetrain 1st Gen Cooper S The great Catch can debate
Discussion in 'Tuning and Performance' started by MCS02, Dec 11, 2016.
  1. DneprDave
    Can't hurt though.
  2. Metalman
    7,700
    Actually it can.... If installed improperly....
    Most of the stuff collected is water....
    If there is a low spot in the hose connection water will collect and with temperatures like we are having today at 8 degrees F, that water will freeze and plug the line.... At which point you can expect high crankcase pressures....
    That's one of the reasons the 2nd gen has a built in heater in the PCV hose that runs to the turbo...:Thumbsup:
  3. ScottinBend
    Best advice..........how much gunk can you live with in the IC?
    10,056
    Darn Scott just drill those holes & that terrible gunk will leak out. My MINI ran fine for 123,000 miles with no catchumup can. I believe it is still running fine for its current owner. Heck if you want a can go for it, but I don't think it is needed.
  5. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    Mmm, not really. My catch can increased crankcase pressure/oil consumption both before and after a new valve cover. The ball valve in my original valve cover still moved freely so I don't think it needed to be replaced but I did it anyway.
    When the ass can was sold my consumption magically decreased. I also think that most of the stuff that collects in there is water/ condensation..
  6. MCS02
    6,303
    I believe I am leaning towards taking the IC off every once and a while and clean it.
  7. 00Mini
    2,254
    At first I would have been leaning towards the catch can but after reading all information that was presented I agree with MCS02's thought of the occasional cleaning.
  8. Metalman
    7,700
    The IC itself becomes a very effective catch can....
    The IC cooling channels offer tremendous surface area and the lower temperature created by the IC help with the condensation onto those internal channels.
    And the IC is exposed to 100% of the incoming air charge....
    You couldn't ask for a more efficient catch can if you tried....
    Pull it off at the beginning of the season and do a solvent flush.... Look at it as a little Spring Cleaning.... Your "S" will thank you..:D
  9. Dave.0
    Yup:Thumbsup: I have doing the above for years without a stupid catch can. :ihih:
  10. bigjas
    bigjas Member
    Sep 3, 2016
    195
    Colorado Springs, CO
    Cool, now I have one less thing to buy!
