The Group4Autosport Progress Thread
Discussion in 'Exterior' started by track-toy, Jun 7, 2010.
  1. JSart
    JSart New Member
    Sep 2, 2009
    I will not be able to get over to be part of this great event, but a few of the other guys have been planning to attend. Wish I could. Go, have fun and a beer or two.
    Joel
  2. yellowbritishrocket
    May 16, 2009
    618
    277
    lol can someone please send me some install instructions for a non-aero r53...this sucker is sitting in my apt collecting dust and it isnt the removable kind so i have to figure out where i need to drill and what kind of bolts i need as i only have the turnbuckles
  3. Dave.0
    Sorry man I cant help you with any official G4 documented instructions but here is what I did with Mark from G4 at MOTD. First off we are men with hand and power tools so we did not need any stinking instructions. :lol:
    We winged it as we where helping Wayne. :incazzato::aureola::idea::prrr:
    Note: My areo bumper is not much different than a stock bumper after you trim off the under lower lip off. The "lower lip" is where the 3 bolts are that hold on the bottom of the bumper to our radiator support.
    This is what we did:
    I clamped (C-clamp or triggered grip lock) the splitter to a table and marked a measured centerline. Use chalk or light crayon.
    Next we took off my front bumper and measured it to find the the center line and also measured centerline. then we lined it up and clamped it on top of the splitter. (Still on the table)
    Next we measured and lined up the turnbuckles. ( drilled black plastic grill and the splitter) ***Measure 10 times drill the grill and splitter once.:Thumbsup:
    Next we lined up the 3 lower radiator bolt holes on the splitter and drilled them out. I did add a few self tapper screws to hold the loose back part of the splitter to the bumper while we moved it to mount it back on the car.
    Next we reconnected all the lights (Side markers and turn signals) and loosly mounted the top part of the bumper back on. We did it loosly so we had wiggle room to get the lower 3 radiator support bolts started. They where a PITA because the 3 radiator support bolts are very short, but my solution to this is below. :idea: The 3 lower radiator bolts with washers hold the lower back portion on the bumper. After we had everything was hand tighted we then locked down everything for good.
    Also use a little blue locktight on the turnbuckles once you have them set correctly or they will vibrate loose.
    Solution for 3 short weak lower radiator bolts:
    When I got home from MOTD I removed the 3 short thin lower radiator bolts and C type clips they go into in lower radiator support. You will know what I am talking about when you remove your bumper. I went to Lowes and got longer stronger bolts and stronger C Clips with wider washers. They made it much eaiser to connect the lower portion of the bumper with the added tickness of the splitter. They are very strong and hold the splitter & bumper very secure.
    Hope that helps as far as an un-official G4 splitter install instructions go.
    Good luck with your install and Motor On! :cornut::devil:
  4. putterfarm
    putterfarm New Member
    May 18, 2009
    299
    Bum.
    Pittsfield, Pa.
    Yo Dave, thanks for helping Roger out. I've been trying to make contact with him for months but with his military schedule it's been inpossible :crazy:
    Yea man we're going to the PVGP. It'll be good to see you :beer Let me know where you might stay. We will be at Leon's on Fri. helping set up :ihih:
    pm or call if you don't have my cell #.
    Mark
  5. Dave.0
    I am going to come out just for the day Saturday and drive back home the same day.
  6. putterfarm
    May 18, 2009
    299
    Bum.
    Pittsfield, Pa.
    yellowbritishrocket, a few added items: for the holes in the grill go over 2 rows and up 8 holes (this is in the solid section on each end of the grill), have 1 1/4" of threads showing on the t.b.s. The hole location on the splitter is at the intersection of the "S" of the relief (in other words draw a line where the curve starts front to back and a line where the curve stops right to left), they'll be about 1 1/2" long each, I use a yardstick. When you clamp the splitter to the facia have the splitter sticking out about 2 3/4" (hold a ruler straight up & down against the facia and measure out on both sides where the splitter holes are). Dave and I used self-tapping screws on the outer rear of the splitter but you can drill a couple small holes and use small bolts, washers and nylock nuts.
    Hope this all helps and don't forget that you have my number and I'm almost always home, Wayne too :Thumbsup:
    Mark
    Ya know Motoring Alliance Professional Services (a wholly owned subsidiary of Motoring Alliance LLC) has been know to be contracted to create professional looking install instructions...as well as handling other Technical Writing needs...manuals, press releases, web content.
    Just sayin..
  8. yellowbritishrocket
    May 16, 2009
    618
    277
    actually i dont need to worry bout the grille as i already have holes from a old splitter drilled in the bumper
  9. goaljnky
    3,105
    394
    Hey Roger. Throw up some pics.
  10. Ladyvalea
    Ladyvalea New Member
    Apr 27, 2010
    41
    lady of luxury
    Fort Worth
    #130 Ladyvalea, Aug 4, 2010
    Hi... My 17yo son is going to be coming with us to MITM...its goin to be a squishy ride with 3 adults in a MCS ! I'm glad he is wanting to come with us! I really want him to see some cool Mini coopers! as he is an American Muscle Car boy!! you know like big ole Camaros and such! I think he can help put on the diffusers and splitters as he like to work on cars too!
    I think we can do it!!
  11. Justa Jim
    Joel, where are you and some teaser shots of the new wings??????
  12. track-toy
    track-toy MINI of the Month
    Test Driver
    Pittsburgh, PA
    PM sent.
    Graham
  13. putterfarm
    May 18, 2009
    299
    Bum.
    Pittsfield, Pa.
    :crazy:
    Hi everyone. We've been so busy building, shipping, making changes, developing some new aero aids and traveling we haven't been on the site (I don't have a lap-top to travel with).
    Hope everyone is having a good summer :Thumbsup:.
    We are going to MITM/MTTS next, hope we'll see you there and make some more friends :cornut:. Come over, say hi and hang around some :popcorn:.
    We have met really great MINIacs on our travels AND picked up a new '03 "S" to turn into a "G4 MINI", black on black on black :D
    Thanks for the really great reception of our aero aids :cool:.
    Mark :beer
  14. cct1
    Any news on the exhaust?
  15. putterfarm
    May 18, 2009
    299
    Bum.
    Pittsfield, Pa.
    :Thumbsup:
    It's coming along nicely. I'll be putting the new design, :idea:, on my new '03 as soon as we get back from MITM/MTTS :D. Let you know asap :cornut:.
    Mark
  16. orangecrush
    orangecrush New Member
    May 13, 2009
    137
    #136 orangecrush, Aug 22, 2010
    Only 1!!!
    Is it possible to get a diffuser sent to me in the next 3 days. I have 4 track days starting Thursday back to back at VIR.
    I'd love to try out one of your rear diffusers. (except I keep hearing there are 3 of them but I only see one on your website)
    I need one now.
    I have 3 days to install a new set of coilovers, powerflex bushings and brackets, rear adjustable control arms, my new rear JCW REAR seats and last but not least, the new Alta AP with tune.
    So why not add a diffuser to the list.
    Oh, did I mention I haven't installed my harnesses or rollbar yet. (harnessed may make it, rollbar, definitely not)
    Let me know.
    Mark
    Collision Specialties, Inc.
    (704) 882-1150
    EDIT: I lied.... 2 questions. I've got the JCW aero kit on my car. Is the diffuser on a JCW kit and regular R56 S the same? It's been a while and I can't remember what it looks like. I'm assuming they are the same because I remember people buying the JCW carbon fiber factory diffusers, no?
  17. BThayer23
    Hahaha, damn Mark, you're really making it easy for yourself, eh?
  18. orangecrush
    May 13, 2009
    137
    You know Ben, I'm starting to see a pattern here. The common denominator is me.
    :rolleyes5:
    :D
    Mark
  19. BThayer23
    Hehehe.
    That car is so damn fast you're ready for some aero anyways. Nothing wrong with being aggressive, but it's fun to watch. :D
  20. JSart
    JSart New Member
    Sep 2, 2009
    Ops, sorry. I have not been on line for sometime now. Working on making the final designed parts. Working with a fabricator, at this time, trying to get the parts into production.
    Will post photos soon of my final design, prototype, so at least you will see the design. Once pre-production pieces are fit, I will also post photos of those pieces.
    Joel
