The Obligatory How did you find Motoring Alliance Thread
Discussion in 'Starting Line - New Member Introductions' started by Nathan, May 7, 2009.
  1. MCS02
    Welcome to MA!
  2. 00Mini
    Welcome to Motoring Alliance !!
  3. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Sooo true and welcome to MA!
  4. Rufflyer
    Rufflyer New Member
    Aug 6, 2019
    14
    Aviation Industry
    Houston Texas
    Found the forum by dumb luck. (most of my luck is like that). Bought a 2003 R53 in July 2019 just for the MTTS in 2020. After that.... who know may keep driving it, may upgrade to a newer generation. OR park it until the next rally.
  5. wmwny
    4,040
    2,242
    Welcome to M/A! R53s rule!
  6. 00Mini
    Welcome to Motoring Alliance the best MINI forum on the interweb. By the way what color is 03 ??
  7. MCS02
    Or you could start modding it. The R53 is the best Mini to mod.
    Welcome to MA
  8. Caryl G Slack
    Caryl G Slack New Member
    Dec 7, 2019
    Marysville Ohio
    Was looking online for Mini clubs close to me and came to this web site.
  9. Dave.0
    Welcome to M\A
  10. 00Mini
    Welcome to Motoring Alliance.
  11. MCS02
    Welcome to MA!
  12. InstrumentOfPeace
    InstrumentOfPeace Active Member
    Jan 10, 2020
    106
    69
    Google search for N18 valve gasket replacment. First result was a tutorial from here. Shockingly well put together tutorial I may add (Clear & Concise). No way I'd pass up joining a site that leads off with well put together tutorials.
    Welcome to M/A
  14. MCS02
    Welcome to MA! Glade we could help. what year is your mini, any mods?
  15. Dave.0
    Welcome to M\A
  16. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Thanks MCS & Dave.
    2013 Roadster S.
    No mods yet. Have a Misfire on Cyl 4. Waiting for new plugs & in the meantime (today) testing compression, pop’n off the valve cover for inspection, and purchasing equipment to walnut blast the valves
  17. 00Mini
  18. MCS02
    I have a 2012 JCW coupe.Roasters are great cars I drove one before I bought my coupe. I almost bought it but when I told my wife my plans for it she said thats what had been done to the coupe. I got it from one of the members here, he did a great job modding it.
    Have you tried swapping out the coil pack to see if the miss fire follows the one in Cyl. 4?I had one go bad under hard acceleration just before redline. I thought I had bent a valve. I limped home checked the compression, it turned out to be one coil pack.
  19. wmwny
    4,040
    2,242
    Welcome to M/A!
  20. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    That I did. Then ODB code Multiple. 1 time. And I didn’t repeat it. I paused. Decided to swap spark plugs. The plugs were sinful black so I (for giggles) hit em with a light sandpaper then put them back in. Hit start and this time I got Cylinder 2.
    I just finished a compression test (10 cycles each) with an even 140 across all 4.
    So I’m hoping like hell its my plugs.
    Guess I could pull the coil packs, pull the fuse pump fuse, rack a plug back into the coil to see if I get spark ‍♂️
