  1. mattc85
    mattc85 Active Member
    Sep 24, 2013
    277
    222
    Heating and Air
    Mocksville, North Carolina
    I felt exactly the same until the perpetual Christmas lights guy moved in across the street. I sort of wish we had one now.
  2. BlimeyCabrio
    This is the most I've ever personally stripped any car...
    I bet it's pretty light, like this.
    Added my seat in, so fab guy can position the harness bar and seat back brace properly. Also, so I can sit in it and make race car sounds.
    I was going to cut out extra sheet metal, left over from the folding top and factory roll hoops. Then I decided to let my fab guy do it, while he's in there cutting stuff anyway. Marked it for him.
    CAEE6EE0-4F79-446E-9DEF-31A7DD6120CB_zpsxr8tki2m.jpg C15FBAE6-A567-406B-A348-F3AEC689E4E2_zpsgfcjw8sv.jpg
    Going in a few minutes to pick up my friend, the Uhaul tow dolly.
  3. Metalman
    Might be a good time to change the fuel filter....
  4. BlimeyCabrio
    Yep, and swap over my DW fuel pump from the other car. Will do both before I put the interior back in it. Might try to do it in the AM before I go to fab... will be easiest without the cage in the way. Good thinking.
  5. ScottinBend
    It's nekkid'.....:D
  6. MCS02
    I am in awe!!!! I have no words.
    You are either a craftsmen or crazy:D
  7. MCS02
    Ok Its not my fault double post
  8. vetsvette
    You did it!
    You did it!
    Paul makes me feel bad. All I'm doing is collecting parts and waiting for the right time to dump them in my Mini guy's lap and have them installed. Got an excuse though... older than dirt and a gimpy wing.
    But, I do love watching your work Paul. When I get to where I can drive my Mini again I'd like to take a ride down there and check out the GP in person. Only about a hour and a half away.
  9. BlimeyCabrio
    I'll have like a "coupon day" or something, with reduced admission and free balloons and pony rides and a bouncy house for anyone who wants to come. :Thumbsup:
  10. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    OOH OOH- a bouncy horse...my favorite. :) Seriously Paul, thanks for posting these pictures. I am saving them as a reference for future work.
  11. vetsvette
    That'd work! And, you could give away SWAG! Everyone that comes takes a piece from the scrap/junk pile when they leave. Save you the trouble of hauling it off.:wink:
  12. BlimeyCabrio
    Good day.
    Swapped my DW fuel pump and new-ish fuel filter from the wreck to the new shell. Much easier without a cage in the way. Hopefully did it right and reconnected everything, so I won't have to fiddle with it more.
    Then loaded up the shell and drug it across town to my cage fab guy.
    I REALLY LOVE IT, when you have a kinda crazy vision for a one-off thing, and you explain it to a craftsman, and they completely "get it" and agree that they can do it.
    I pretty much knew that I wanted the rear of the cage to be very similar to my old roll bar, just wider and with a better brace mounting location. But the front... that had to be designed.
    I want a relatively open top (no braces across the top), relatively unobstructed entry and exit from the car, retain all front factory trim, as little obstruction of view as possible, look as clean as possible. But also be very stiff and safe. I'm not going to race this car wheel-to-wheel, so I don't need to comply with racing side impact rules. While I do need to pass time trial rules, just the roll bar was sufficient for that. But... if at some point I take this car airborne at 100+ MPH on track, or slide it down the side of a mountain... I want to have a fighting chance.
    I've looked at hundreds of photos of caged MINIs. Out of all those, I found one example that really clicked with me.
    HPA Motorsports "Gokart"
    Front pillar hugs the A-pillar and goes through the dash, fitting between the door speakers and the fusebox / BCM. Knee bar under the steering column, goes behind where the stereo head unit would normally be. Single door bars bow out into the space between the door handle and the door painted trim. This design is really clean, and retains the factory trim (though some things will need some trimming, obviously). Will probably have an open halo top, but we'll figure that out for sure after the main hoop is built and tacked in.
    It will probably force me to remove or reposition the stereo headunit, as there's not enough depth in there with the knee bar in place. But the structure won't be stiff enough without a crossbar, and I think putting one on top of the dash is hideous. I really don't need the headunit... I could just add a simple amp with an aux input and a volume control, and I'd be fine.... that may be where I'm headed.
    My cage guy also was fine with cutting out the extra stuff in the rear.
    My current thought is to paint the entire cage Pure Silver with clear coat. So it matches the GP interior and exterior trim, as a GP roof would....
  13. TheModFather
    Definitely go with the pure silver on the tube work, it will add class and bring the whole concept together in my opinion.
    The shell looks much better without all the baggage (soft top) hanging off the back.
  14. ScottinBend
    You might consider a simple bluetooth speaker system if you have a phone or such you can play music on.
  15. BlimeyCabrio
    Nah, I need GOOD audio. I'll hook up and drive my HK speakers one way or another.
  16. TheModFather
    You can get an AUX jack to RCA cable adapter at any electronics store... BOOM DONE!
    I've ran many systems like that.
  17. BlimeyCabrio
    Yep, not hard. I never use the radio in the car anymore, anyway. Just aux input. If I can figure out how to rework volume controls with my steering wheel paddles direct to an amp... Done.
    Some folks move the toggle panel up to the spot where the radio head unit was...
  18. TheModFather
    Volume control is a little more tricky... Sometimes I would just run an external equalizer with a master control, but that complicates things a bit... And lets face it, you're not building the G3ness for audio competition. I would just get a good mount for your phone or i-Pod, and control the volume off of that.
  19. ScottinBend
    I have heard some killer Bluetooth speaker systems. Sounded better than my home Yamaha receiver and floor speakers.
  20. BlimeyCabrio
    In a convertible?
