  1. BlimeyCabrio
    Yep, already plan to put a rubber grommet in them.
  2. TheModFather
    Locutus - The GP Roadster Project
    Didn't know that! But that sucks! I love the fuel door on the R53, wish I could adapt one to the Porker...
  3. BlimeyCabrio
    Rear stuff is DONE.
    Porn:
    Added a hardened washer on each side as a shim between shock and control arm adapter, to get a couple extra mm of clearance between the shock body and the arm.
    Cables, lines and sensors all connected. Just need to fill and bleed brakes later.
    Also ran meth line from the boot to the front...
    Added rubber grommets in the adjuster holes...
    Will start on the front this weekend.
  4. 00Mini
    Very neat and clean looking installation !!
  5. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Making some serious progress now!
  6. BlimeyCabrio
    Today's progress: got started on the front suspension.
    Dropped the front subframe. Yeah, lift and tall transmission jack come in handy. Dropped the whole thing intact in less than 10 minutes. 10 bolts + 6 nuts.
    Pulled it out and stripped everything off it. Cleaned up and treated some rust.
    056AD4DE-30F2-4B1D-8FBB-2AF444BC9CC9_zpsoavhk92v.jpg E26126E1-C140-49C7-BE9E-7901F8E818D7_zpsggkcht15.jpg
    Pressed out my 100k mile old Powerflex purple bushings and pressed new Powerflex black bushings into the LCA brackets.
    Installed new lower control arms (wishbones), the bushings, and Hotchkis sway bar.
    Decided I needed new ball joints. Didn't find any locally, so ordered a set. Will be delayed for a few days until they get here.
    Pulled off the steering rack to save as a spare. Installed my old steering rack with pump and reservoir still attached. Used new Powerflex purple rack bushing. Installed two new tie rods.
    Maneuvered the subframe back into position, raised it, and popped in 10 bolts. Done. That jack is AWESOME.
  7. old81
    Great progress, when does the engine go back in?
    Nope, not in a hurry, just want to know. :)
  8. BlimeyCabrio
    I expect the motor to be in, within the next week or so.
  9. BlimeyCabrio
    Productive day in the engine bay.
    From this:
    To this:
    Installed tons of hole plugs.
    Routed front body harness (both sides).
    Wired headlights, re-routed cables.
    Installed A-panel and bonnet plastic alignment brackets.
    Installed DSC / Brake booster / Master Cylinder / Brake lines, connected brake pedal.
    Installed complete wiper assembly.
    Installed all firewall trim and brackets.
    Installed extra heat shielding in tunnel.
    Installed PS pump bracket.
    Installed motor mount.
    Installed fusebox.
    I really like the way the underside of the bonnet is looking. Spent some time routing the wiring to make it as hidden as possible. Not running washers. Really clean.
    Here's the extra Design Engineering heat shielding I added to the tunnel. Because that area gets pretty darn hot. The coating on the header should hopefully keep things cooler up front, but the cat will be pretty much right under the shifter, at the front of the mid-pipe. Hopefully this will help. I'll be installing the OEM heat shield over this, might need to bend it a bit for fitment.
    Getting close to being ready to hang the motor... finish line is in sight, finally!
    Still lots to do before it's done, but it's starting to feel real now!
  10. TWISTER
    TWISTER Active Member
    53
    Web Developer/Designer
    Piedmont Triad, NC
    Great job Paul, can't wait for you to lead a run soon like the old days!
  11. BlimeyCabrio
    Great to see you in a MINI again, old friend. :Thumbsup:
  12. BlimeyCabrio
    #1052 BlimeyCabrio, Dec 7, 2015
    Just played with it for a couple of hours today, between other things.
    First... while retrieving my rake to do some yard work, I bumped a box of hardware and it went everywhere. After a few choice words, I picked it all back up, piece by piece. At the bottom of the pile, was this...
    This is the unobtainable clip that locks the clutch line on the bottom of the master cylinder. I've been looking for it for over a month, through about 10 boxes of mixed hardware, and haven't been able to find it. Karma, my groovy babies. Recommendation: if you ever take this thing off, stick it back in the master cylinder slot for safekeeping.
    Next, I decided, it was time for some really expensive vinyl. Paint has cured over 3 weeks at the recommendation of my painter.
    687770D2-7E08-48E0-89EE-85B560BF0B99_zpsnhpyv5uh.jpg 3EACCFAB-EAB4-478E-BEBB-1C32194F3A85_zpssxlrh7uh.jpg
    Really completes the GPness.
    And a proper paint code sticker. Arrived today from Germany, via eMINIparts.
    Painted and installed the cabrio braces that came with the new shell.
    64AD1418-C32B-4165-B440-1981FA126560_zpstoaf1vmq.jpg EA286F02-DB9B-45DF-A4A3-DE1AFD420E01_zpsthahmzbr.jpg
    A few of you very observant folks may have noticed in some recent photos... the paint on my cage failed. I had noticed it flaking a bit. When I put the painters tape on it, and removed it, it lifted. I blame the self-etching primer, because it lifted all the way down to the steel. Bummer, but I'd rather find out now, than later.
    Sooooo.... I've been researching and testing various things to decide on the best path to remediate that. Finally decided to use POR-15 Silver, plus POR-15 Silver Top Coat to make it UV tolerant. Wish I had done that originally, the color turns out to be really close to the Pure Silver. Oh, well. Stripping the existing paint and masking everything off will suck. But the new paint will be MUCH better when done and cured. After checking colors on pints of the POR stuff, I ordered quarts today, to ensure I have plenty. Will probably work on that next week.
  13. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    701
    762
    Oracle DBA
    Skokie Ill
    Can I say that I like your GPness?
  14. Metalman
    ^^^Awww Crikey....
    Now you've done it...
    It can't be undone....
  15. BlimeyCabrio
    You won't be the first.... or the last.
    My GPness
  16. Metalman
    That's Gold Paul..... Pure Gold....:D
  17. ScottinBend
    HA!!!!!
    :Thumbsup:
  18. RallyMini370
    Love the rear suspension! The project is coming along nicely. Next you should build a rally car version!
  19. cct1
    Nope. Paul can get more altitude with a road car.
  20. TheModFather
    LOL! The GPness shall only go vertical once!
