Brakes Wheels 1st Gen Tires Thoughts / advice?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by WolfGTI, Dec 1, 2009.
  1. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    I am looking to run 225/45 16's on my 2002 Cooper S. I have koni yellows and TSW springs. The ideal rim width would be 16x7.5 - anyone have advice on the offset needed / what rims are available that would fulfill the specs. I have been looking around but haven't found much.
    Thanks in advance.
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    I'd go to tirerack's or discount tires website and either input your spec's into their search engine and it will narrow down your choice immensely to just wheels that more than likely fit. Talk to a rep too and make double sure. You can take that info and buy something from them or at least know exactly what parameters you have to work with
    My experience is most other sites assume you know what your looking for
  3. chuckt
    chuckt New Member
    Oct 16, 2009
    19
    I'm running that size in Hankook RS2's on some SSR Comp knock-off rims they are 16x7 et 44. No rubbing unless heavily loaded w/ large dips or bumps. No problems at all with normal or even hard driving.
