Now could be the time to 'upgrade' that cylinder Head. Thumper Performance Ported Cylinder Heads have been proving themselves all around the World. With MORE Power on the r50's and the r53's. Get a cylinder Head that is made to YOUR needs and driving habits. Bolt on Power and Performance and also the added advantage of more MPG!! We offer THREE different models.. Because we do our own work, we can modify the Heads to your spec., More compression wanted?? Running the OVAL Tube OBXr Header ?? High lift camshafts and need more valve train clearance?? We do the custom builds that you might have a hard time finding from other Cylinder Heads. Until JUNE 15th .. we are offering these Heads for $200.00 OFF !! Still FREE SHIPPING to your door in the US. . TPR1 $1295.00 now... $1095.00 TPR2 $1695.00 now....$1495.00 TPR2r $1895.00 now.. $1695.00 Our other products are also discounted for this short time until June 15th. AdjustED Cam gears... Gaskets for R&R.. Ported Matched Intake Manifolds.. ARP Head studs.. Keep in mind I still will Ship to you FREE in the US!! Showing a Basic HP and TORQUE Improvement by Degreeing the cam with the AdjustED cam gear.. All Standard Core Fees apply. Thanks Thumper
AdjustED Cam Gear Running your car at the track on weekends?? You installed the Schrick camshaft, as that was the best at the time. And you have been thinking of upgrading your camshaft for more power in the lower rpm range to get you out of the turns and faster to the straights?? Feel the need for a bit more torque on the DD when the track isnt the issue, and yet dont want to loose that strong top end charge of the Schrick?? It is as easy as advancing the Schrick Camshaft !! My AdjustED Cam gear is already Degreed for your camshaft and a bolt on easy part, to gain the torque and HP from the camshaft. No need to spend on a new camshaft... use what you have and Rock!! Thumper AdjustED Cam Gear: $225.00 Exchanged FREE Shipping in US and the UK
Look at the spec on the camshaft.. ICL and LSA numbers... add in the S/C and changing the cam phase, and you have a power gain thru the ENTIRE RPM range. Keep in mind the facts and the statement that if you advance you gain torque -but loose top end, is ALL dependant on the LSA and spec of the camshaft and the induction!! Go back to the first post and look at the dyno of a degreed camshaft.. the slight blip at 7300 revs was do to me running OEM inj and stock Map!! Looking at the dyno you can also see that the MID range was opened up.. a Plus+ Plus to any camshaft.. Just saying..................................... Thumper
What's the best way to contact you? I just found out from my mechanic that my head has to come off, and I think this might be a good time for me to upgrade...
Jeff the best way is email... [email protected] let me know what you are looking for.... Thanks Thumper
