Question Engine R55 Clubman S Timing Chain Issue
Discussion in 'General Technical Questions and Answers' started by Colin Bailey, Apr 16, 2020.
  1. Colin Bailey
    Colin Bailey New Member
    Apr 16, 2020
    I did a timing chain on my car. The tensioner went out and I replaced it all and put the motor in time and I have engine code P15E8. It's not starting and I need it running asap. How do I fix this.
  2. wmwny
    4,040
    2,242
    Welcome to M/A!
    What year and model is your car? Lots of owners are on here, but, unfortunately, I'd be the last you might want to ask for help. Worry not. Someone with real experience will be along to help you.
  3. Dave.0
    Every R56 owner ever.
    10,059
  5. MCS02
    6,308
    #5 MCS02, Apr 16, 2020
    Welcome to MA! Knowing the year and type of Mini would help. The only advice I can give for now is make sure every thing is plugger in correctly. Your thermostat may have two plugs( if its a Gen2 car with an N14 motor the N18 I am not sure of) make sure they are plugged in correctly.
    Here is a link to the Gen2 Mini codes.
    https://www.motoringalliance.com/articles/ecu-codes-chart-2nd-generation-mini.57/
    after installing the chain did you turn the motor through one revolution and relock down the flywheel and cams to make suer the timing was correct?
