1st Gen R50 Cooper today was utterly horrific
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jbkoopa, Jan 18, 2010.
  1. goaljnky
    3,105
    394
    You are right. See, I told you I was mistaken.
    I agree. I think stock size on X-Lites is 195-55 so 205-50 should be so close it shouldn't make that kind of difference. Also, I don't have their dimensions but it seems like there ought to be more room next to those V-Maxx coilovers than the stock springs. Very strange. I guess if there's nothing else unusual going on then a small change might be enough.....maybe. It's impossible to be sure without getting in there for a close look.
  3. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    Check the alignment before trying another set of tires. Not fun to buy all new tires just to find the same problem coming back again.
  4. i should've taken pictures lol.
    but if you can use your imagination, think about looking under the car and seeing the bottom perche of the coilver having a lot of pieces of rubber stuck in between each little space on the perches, and imagine the inner tire wall of the 205/50 hitting that perch. its a lot of rubbing :(
    would gettign 195/50 or 195/45 tires be a good suggestion for new tires?
  5. oh and there isnt a lot of room on the inside for high offset wheels.
    thats why i need wheels! :D
    wheels with low offsets :lol:
  6. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
  7. bee1000
    bee1000 New Member
    Dec 23, 2009
    176
    Marketing
    San Diego, California
    Hmm...I've had 205/50 tires on my X-lites for 13 months now and haven't been told of any rubbing in all the times they've been rotated. I'm on stock suspension, though, so I guess that is making the difference.
    The stock size for them is 195/55 (when you go down in width, you need to go up in aspect ratio to keep the diameter roughly the same). Tire Rack doesn't show much available in that size if you're looking for a performance tire (summer or all season). I think some people like the Kumho Ecsta SPT XRP, though.
  8. so im guessing 195/45 are out of the question huh?
    i do wanna try to make the look of the wheel/tire combo good too lol.
    and large sidewall :yikes:
    but if i gotta get 19/55 tires then i will, im just asking if 195/45 would be okay.
  9. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Thats about a 10 on the 'suck-o-meter'
    sorry dude
    Run a few options through the calculator on this page (look for "A tyre size calculator" a bit more than half way down the page). If I were you I'd punch in the original 195-55-16 size on the current side. Looks like going to 195-45 will have quite an effect on your speedo and odometer readings. On the other hand, the smaller overall diameter and circumference will improve the gearing for acceleration (and reduce your top speed). I know people who have gone with even smaller diameters for just that reason but remember the look and wheel gap will change as you go smaller. For example, the difference in radius from 195-55 to 205-50 is a reduction of about one centimeter while 195-55 to 195-45 is a reduction of almost twice that.
    If it was me, I think I would consider some spacers and another set of 205-50...or maybe 205-45 if they make them...maybe.
    FYI. I've posted links to the Tyre Bible site before. To anyone who had followed those links: the guy rearranged his site and moved things around so those old links (if you saved them) may not work anymore.
  11. garbageburrito
    garbageburrito New Member
    Jan 11, 2010
    Programmer
    KCMO
    Man, I know how you feel. Hopefully Brad Pit killing Nazi's and some empty calories will make you feel better.
  12. RonsMinnie
    449
    Sugar Land, TX
    I wondered what happened - Thanks for re-linking this site, it is a good one.
  13. ScottinBend
    In a bowl of instant rice.
  14. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
  15. lotsie
    stagehand/part time detailer
    Right here
    Unless the phone is a Nokia, then you would put it in a bowl of dry porridge.
    Mark
