TPMS problems
Discussion in '2nd Generation: 2007+ R55 through R61' started by cristo, Oct 21, 2018.
  1. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    I think these TPMS sensors have PMS.
    • Funny Funny x 2
    • Winner Winner x 1
  2. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    #22 cristo, Oct 23, 2018
    Yep, drove a few more miles after dinner
    and Jeopardy and the ⚠️ is back.
  3. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    Emailed the sensor company, who then
    talked to the tire shop, who then called me.
    They say they now have the correct configuration
    data for my make/model/year/build date,
    and that their application tables weren’t
    strictly correct for my vehicle, and they
    want to try configuring the sensors again.
    Will stop by late Friday afternoon or early
    Saturday am to give them another go at it.
    Good luck, hope 3rd or 4th time is the charm.
  5. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    The third time wasn’t charming at all. The shop took the advice they got from U-Pro and
    tried to reconfigure the sensors with a different year's file. For some reason they suggested
    using 2010 instead of 2009 even though that's after the change to a different oem sensor
    per realoem's part numbers.
    They then tried 2008 but couldn't get the file to write and I'm back to square one again.
    They had it in the bay 3 times over a couple hours. Since the U-Pro rep was so convincing
    that their suggestions would work this time, they hadn't ordered a different brand sensor as
    they were originally going to do earlier this week, and now I'll have to wait until Tuesday
    afternoon for them to (hopefully) get Huf or Schrader sensors (MINI oem brands).
    This is a shop that has been around since 1961 and I have been going there for decades
    without any previous problems at all, and since it looks like it's primarily a manufacturer's
    issue, I'd like to give them another chance to do it right with a different manufacturer.
    I'm waiting to be charmed for real next week.
  6. Dave.0
    Ugh ! That would have pissed me off, but like you said you have been going to them for decades and this is your first issue so I understand cutting them some slack.
  7. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    Plus the car is perfectly drivable like this
    and there’s no real urgency to getting
    it settled correctly.
    But it is still very frustrating and I would
    prefer it fixed sooner than later.
    • Agree Agree x 2
    • Like Like x 1
  8. Mini Q
    Mini Q Member
    Nov 11, 2010
    46
    Fullerton, CA
    The correct frequency is 433mhz. Return the Upro sensors and get Huf.
  9. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    Installed ones are programmable 433 MHZ
    U-Pro and I gather the main problem is in
    the programming.
    The shop is ordering Huf or Schrader and
    should have them by tomorrow.
  10. Mini Q
    Mini Q Member
    Nov 11, 2010
    46
    Fullerton, CA
    That’s good. Huf is the only one known to work on this generation of Mini
  11. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    Tire rack sent me my summer tires and
    wheels with Huf RDE048V21 sensors in
    them last May just after I got the MINI, and
    they worked immediately without any
    problems.
  12. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    Took the MINI in for the FOURTH time. They were supposed to have an oem Huf or Schrader ordered at this point.
    They said they tried another sensor set (didn't recognize the brand, but it wasn't Huf or Shrader), and they said it didn't work.
    They then put in another U-Pro set and programmed it for 2008 and drove it 15-20 miles and pronounced it fixed.
    I checked a scan which said the sensor positions had not been acknowledged yet, and sure enough, in just a couple
    more miles, the light came back on. Tried resetting it and it took a couple miles for the light to go out, but it came
    back on in a few more.
    I ordered the same Huf sensors (RDE048V21) from Tire Rack that worked instantly without programming on my summer tires,
    and will get another shop to put them in the winter wheels and re-balance Friday or Saturday (they should arrive Thursday).
    Wow what a cluster fark. I hope the shop refunds all your money & maybe compensates you for this TPMS hell they've put you through.
  14. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    They are indeed on my list.
    I will save the sensors and return them
    to the first shop for a refund of
    applicable parts and labour.
    I’ve also sent a couple nasty-grams to
    the manufacturer for U-Pro.
  15. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    #35 cristo, Nov 2, 2018
    Had a second shop put in 4 Huf rde048v21
    sensors and it reset quickly, correctly, and
    permanently.
    Returned the other sensors to the first
    shop and got a refund on the parts and tax.
    Glad it’s finally straight.
  16. 00Mini
    2,237
    Hallelujah !! It’s got to be a relief to finally have everything worked out to your satisfaction.
    • Like Like x 2
    • Agree Agree x 1
  17. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Wow - never seen or had this problem before. Glad it's figured out, seemed like a real PIA.
  18. cristo
    Jan 4, 2015
    5,681
    916
    physician
    York, Pa
    Still not sure if the incompatibility was the
    U-Pro sensors themselves or the
    programming of the sensors or both,
    but I’m sure glad it’s all working with the
    Huf sensors.
    I suggest staying away from generic
    programmable ones for these MINIS
    unless your shop has had previous
    success with them with your year and
    model.
    • Agree Agree x 2
    • Like Like x 1
    • Informative Informative x 1
