1st Gen R53 Cooper S Transmission failure?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by fhtagn, Sep 22, 2014.
  1. fhtagn
    fhtagn New Member
    Sep 22, 2014
    16
    Sounds fun! So the transmission is user serviceable? I mean, even unofficially is fine as long as I can find parts. =)
  2. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    Your problem seems to be internal to the transmission so you have to pull it out. Once it is on the ground, with it in a gear, you can spin the input shaft to see if the output also spins. If the input and output are not positively connected you have nothing to lose cracking the case open. There are how to videos and threads for installing limited slip diff's that will cover splitting the case. I don't know what parts are available besides differentials but maybe you can get lucky.
  3. fhtagn
    fhtagn New Member
    Sep 22, 2014
    16
    So I think Jack Nicholson may be right...I had tested the shorter drive shaft by pulling the wheel end loose and rotating it to hear the gears in the transmission move, but I never did that on the other side. Well today I was pulling it apart again to drop the trans. I compared the drive shafts; The short ones matched, the long ones didn't. The one that I ordered and installed seems shorter from the bearing carrier bracket to the transmission. I don't know if you can see it from the pictures, but only like 1/16th inch (or less) of the thread was contacting anything inside the transmission. The part that was was ground off. I guess might have been what I heard when I first put it all together and tried pulling it out of the garage? So...I'm going to order some of those drive shafts that you linked, Dave, but is there anything that I need to know as far as options? I mean the one that I got looks almost perfect, the bracket mounts up, the splines seem to be the right amount to fit, but the length was just a bit short. Did I get a non-S version or something?
  4. Dave.0
    Nope you should be good with the DSS or RMW axles. :Thumbsup:
  5. fhtagn
    fhtagn New Member
    Sep 22, 2014
    16
    Is it relatively straightforward to remove the bearing carrier from the old and put it on the new?
  6. fhtagn
    fhtagn New Member
    Sep 22, 2014
    16
    Interestingly enough I found out, from a thread on another forum, that all I needed to do was switch out the bearing carrier from my old drive shaft to the one I had bought. So...as much as I would love to spend $400 for a second set of new drive shafts as advised, I opted just to use the ones I had already bought. Thank you everyone for the help.
