1st Gen R53 Cooper S Transmission oil change
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Newbie6, Apr 27, 2015.
  1. Newbie6
    Newbie6 Member
    Apr 7, 2015
    Hey guys I'm looking to get my oil changed out because I refuse to believe the oil is lifetime despite what anyone tells me. So I was just curious to know how hard is this to do? Has anyone done it or had a shop do it? I'm just wondering if it's just a easy drain and fill or is it a pain to remove things to get to the plugs?
    is it a manual?
  3. Newbie6
    Newbie6 Member
    Apr 7, 2015
  4. Metalman
    The first and most important step.... Remove the fill plug first... If you can't remove it, don't remove the drain plug...
    To fill it... use a funnel with a length of tubing from above the engine... or one of those hand pumps from under the engine...
  5. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,652
    912
    physician
    York, Pa
  6. Newbie6
    Newbie6 Member
    Apr 7, 2015
    Nice, thanks for the help guys, I searched for this but nothing showed up for me when I searched so thanks!
  7. MCS02
    If you have a air compressor you can put a peace of fuel hose in the top of the bottle and seal it with tape. Then poke a small hole at the top of the bottle. Turn your compressor down to 20psi. put the hose in the fill hole and blow air into the small hole. fills right up.
  8. ScottinBend
    I just used a bit of hose and a funnel......worked great.
  9. Newbie6
    Newbie6 Member
    Apr 7, 2015
    So I'm guessing you don't have to remove anything to get to either plugs then?
  10. minintrigue
    minintrigue Active Member
    Sep 30, 2009
    233
    Banker
    Cincinnati, OH
    Not that I recall.
  11. ScottinBend
    Both plugs are easily gotten to from under the car.
  12. Newbie6
    Newbie6 Member
    Apr 7, 2015
    Sweet that's good to hear, I just have a feeling this car has never had it changed and it's at 130K so it's time for a change
