2nd Gen Transmission Rebuild?
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Grizld700, Feb 1, 2018.
  1. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    So last year during autocross I started experiencing a 2nd gear issue. During a hard or long sweeping turn 2nd gear would just be gone. The shifter is still in position. But power is gone. Take it out and try to put into gear and it grinds until the car slow a bit. Then goes into gear just fine. I even tried turning with one hand instead and the other holding the shifter to see if it'd stay in gear with mixed results.
    I've tried a couple things. First was to change fluid. It was redline ATF. The fluid was a little metallic. Not a good sign. I put in Motul 75w140. The feel of the transmission improved, but the next AX it still did the same 2nd gear thing. The second was to replace the transmission mount, in hopes it was worn and allowing the transmission to travel too much when the vehicle is loaded in a turn. Well, like before, at the next AX it happened again.
    As for regular driving it happened maybe twice. Both when going over a curb transition into a parking lot. And this isn't my Daily Driver anymore. So I've considered leaving it alone. But as time goes on it keeps bugging my brain.
    Now the back story is done, here's the question. Does anyone sell a gear set for these transmissions? I haven't found anything in my brief searching. I can find used transmissions, but I'd prefer rebuilding with new gears, or even changing the gears to better suit my track / AX needs.
    6,316
    @Grizld700 I have not hade this problem on a Mini but it was common on the brands I use to work on as a mechanic.
    On Alfas it was common for second gear to do this. What caused it was a broke tooth on the gear. This was usually accompanied with the second gear syncro going out. There were different reasons for the tooth barking, the syncro was because people would hold it in gear and wear out the syncro. Fiats X 1/9s it was revers. That was always because someone would push start it in revers.
    I feel sure if there was metal in the oil your second gear is damaged.Having to slow a little to get it in gear sounds like your syncro is going. Time to rebuild
  3. MCS02
    6,316
    I dont know if a used transmission would be cheeper, it depends on what you have to replace in your transmission.
    I would rather rebuild my transmission that way I would know it was strong.
  4. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    See I'd prefer to rebuild. The problem I'm having however, I can't seem to locate replacement gear parts. My googling powers must be weak.
  5. MCS02
    6,316
    It would appear that my google fu is weak also
  6. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    You said Alfa... heheh.. I had a love affair with the....
    And
    Ok.. I’ll stop highjacking this thread.. fun cars to drive. Complete PIA to maintain. (NOTE - I never ended up buying one.. those were not my cars. Just what I expired to do should I own one.. )
  7. Tigger2011
    Tigger2011 Member
    Oct 30, 2013
    38
    25
    Fort Lauderdale, FL
    Hey Griz,
    Did you try Getrag Gears of North America? Haven't used them myself but they're in Newton, NC. Ph. 828-428-1591. Worth a call maybe.
    • Like Like x 1
    • Informative Informative x 1
  8. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    I have not! I'll have to give them a call. Thank you :) Sometimes the best answer might be the easiest.
  9. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Let us know what you find..
  10. kimpanasan
    kimpanasan New Member
    Feb 22, 2018
    I have a r56 and I lost power from 2nd gear also. I tried Fluid replacement, valve body from rev max and now I’m hoping it’s not the tranny but the connectors to the valve body. I really don’t want to shell out 9k to have this tranny replaced due to basically a whole engine drop.
  11. MCS02
    6,316
    That would be a big bill!
  12. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    I'm glad I don't have an automatic!
  13. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    OK - that seems really expensive..?? 9K? What am I missing here?
  14. MCS02
    6,316
    Says the guy with two M5's!:D BMW/MINI thats what happened. But for the life of me I dint know why the transmission are so much!
  15. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Lol - you have a good point. The M5 transmissions (even the 88 with the “special” transmissions are not that much). The engine on the other hand.. that is expensive on the 88. The 03 isn’t that bad.. talking used that is, not new. :)
