TSW Engine Mount Prototype
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Nathan, Jun 5, 2009.
  1. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    Ahh, I get it now :)
    Thanks for your answer
  2. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    So, that begs the question(s):
    What would be the T rise from outside to an inch or two away from the mount? So, basically if it is 120F outside air temp, what is the temp at the mount on track day?
    Just trying to understand the mount temp spec margin to worst case real-world conditions.
  3. Deviant
    Deviant Banned
    Student
    Southern IL
    I've kinda wondered this myself since I can't really see any rhyme or reason to the stock ones failing except that maybe underhood temperature's heat the fluid to a point where it either becomes thin enough to leak or expands enough to damage the seal.
  4. Mike
    Mike New Member
    I've assumed that the temperature could get as high as 200F near the motor mount. Hopefully (for our plastic-filled engine compartments), that's a guess on the high side. The charge cooler does vomit really hot air all through the engine compartment, and so does the radiator.
  5. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    No lull here. Come out to ECR on the 11th air-conditioning boy!!! :ihih:
    Alan
  6. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    I'm glad this mount is out. I just found my sister's engine mount has failed, so she will probably purchase one.
    For those who have replaced the mount themselves, do you have any tips for the job that might not be obvious from reading the Bentley manual, say? Thanks.
  7. Deviant
    Deviant Banned
    Student
    Southern IL
    I had to learn what a Reverse Torx size 12 is while laying under my car with everything else already off, make sure you have one on hand or that you can convince the local store to deliver.
  8. BlimeyCabrio
    Yeah - what Ken said ^
    Been there, done that.
    Otherwise, it's pretty straightforward. That reverse torx (aka "star socket") bolt may be REALLY tight and/or corroded, also...
    But as long as you have a floor jack to put under the engine, and the right sockets and extensions, it's easy.
  9. mini_racer
    Engr Manager
    Bolt corrosion
    I also found that long bolt to have some corrosion on the smoth part of the shaft. If you find any corrosion optimally you should just change the bolt, but in a pinch you could just clean it up and lube it or seal it with an etch primer. etc and reuse like I did. :D
  10. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    OK, tips noted. Thanks, guys!
  11. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    The bolt in question is a single use, torque-to-yield bolt. Use a new bolt for the install; tighten to 41 ft-lb and a torque angle of 90 degrees. Drive the front up on ramps, remove the hydraulic damper top nut, raise the engine enough to relieve pressure on the damper, remove the bracket from the block, remove the E12 bolt, and remove the pitch bolt from the body. A how-to for the early model [ame=http://www.lonestarminiclub.com/forums/showthread.php?t=526]Engine Suspension Replacement - Lone Star Mini Club Forums[/ame] some of the photos are similar to the later model procedure.
  12. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    Excellent. Thanks! :Thumbsup:
  13. scott@txwerks
    scott@txwerks New Member
    Units are in production... Finally. We expect to receive the first shipment at the end of next week. We'll hold on to them for a few days for final curing (which takes 5-6 days for what we spec'd), but should start shipping a week from Monday.
    With Dr. Mike's design, the engine damper kits we sell are no longer necessary - guess we'll kill that business! :) Oh well - no more oil puke to clean up and no more replacing a crappy mount with another crappy mount!
  14. Uncle
    Uncle New Member
    May 24, 2009
    119
    Anxiously awaiting for the new mount from you guys and RMW's new crank pulley. My engine rebuild should be about complete.
  15. FUEGO
    FUEGO Club Coordinator
    IT Geek
    DFW Texas
    Gonna miss that one. I'll be in San Diego for a couple of weeks and although I'll be missing my MINI I won't miss the heat. July DEs here can be brutal :crazy:
  16. wotagame
    wotagame New Member
    May 20, 2009
    15
    I am pleased to report that I was able to snag one of these mounts at our recent DIY day here in Dallas, and it really looks like TSW has nailed the design.
    Now can anyone tell me how I can clean up the old nasty hydraulic gunk that my former mount excreted into my engine bay!
  17. mini_racer
    Engr Manager
    Isopropyl Alcohol works well.
  18. Mike
    Mike New Member
    K1 Kerosene also works nicely.
  19. wotagame
    wotagame New Member
    May 20, 2009
    15
    Have you considered doing the urethane in different colors? Just a thought...
  20. mini_racer
    Engr Manager
    Yeah, gimme red.:cool: It is the fastest color afterall.
