From Way Motor Works siteThis M14 to M12 wheel stud conversion kit is your solution for your R52,R53,R55, R56, or R57 that came with M14 studs and you can't make those aftermarket wheels or brake kit fit. This will keep you from drilling out those expensive wheels, or through the rotor hats. Also will make changing wheels easier if you don't like the lug bolts. Changes from M14x1.25 to M12x1.5 so finding lug nuts will be really easy. Made in the USA of premium steel, black phosphate finish, bullet nose for easy threading of lug nuts. The wheel studs are 65mm overall length with 52mm protruding from the hub. Contains 16 studs enough for 1 MINI, nuts not included. Works with 2007+ Cooper Works with 2007+ Cooper S Works with 2008+ Clubman Works with 2008+ Clubman S Works with 2009+ Cabrio R57 This set is used and was on my MINI for less than 1 year. All are in perfect condition. This set sell for $89 from Way without nuts, but you can get my set for $50 and do include 16 nuts. They have all been ultra-sonically Cleaned and oiled to prevent rust. Buyer pays shipping from 27106 USPS Priorty Mail
I just bought a set of team dynamics 1.2 the gentleman I bought them from said I will need 12mm conversion. I am still unsure because forums said it will work. I will check tomorrow to make sure if I need it I am interested.
Yes I think the TD wheels have a much smaller hole for lugs/studs. That's why I bought these. My wheels needed 12mm studs.
very interested, issues with paypal at the moment(clicked bad ebay link) any other means of payment accepted?
