Engine Drivetrain 1st Gen Cooper S Updated - April, 2010 - Magnetic Drain Plugs after 4.5K miles
Discussion in 'Tuning and Performance' started by Nathan, Jul 26, 2009.
  1. ScottinBend
    I am sure the oil temp sender is the same for both.
  2. Deviant
    Deviant Banned
    Student
    Southern IL
    It's not, I've seen the drainplug sensor on a friends car and my car has a normal plug. I'll have to go through RealOEM and try and find my sensor, it would be a good thing to know the location of if it ever were to fail.
  3. not-so-rednwhitecooper
    Aug 5, 2009
    40
    mechanic
    Chardon, Ohio
    I have asked the same thing many times over the years, and nobody can give me a good answer.
  4. ScottinBend
    Well let's keep looking/asking. Inquiring minds want to know !
  5. Deviant
    Deviant Banned
    Student
    Southern IL
    The only thing I can find on either RealOEM or in the Bently Manual refers to a pressure switch near the filter housing but the gauge I have does vary depending on engine RPM and oil temperature so I know it's not a dummy gauge like Ford used to do (where the oil pressure gauge was actually just a camouflaged idiot light that would show standard oil pressure as long as there's a little oil pressure.)
  6. Nathan
    #46 Nathan, Apr 17, 2010
    Lest ya'll thought I forgot....
    Today at the MM.org DIY Day hosted by the very accommodating MINI of Dallas it was fluid change time during my pre Dragon "tune-up".
    it was July of last year since the last engine and gearbox oil change. I've covered a whopping 4712 miles since then. Note to self when this revisited at next change 45,528.
    Yes I know there is really no reason to be changing the gearbox oil at this time. I wanted to see what the magnets had attracted.
    Engine
    Gearbox - Lower Plug
    Gearbox - Upper plug
  7. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    They seem to be working well. We are using the magnetic plugs in most of our regular customer cars now. Sad to see that much metal, but good thing the magnet is catching it.
  8. ScottinBend
    So does anyone think that a magnet attached to the filter housing would do any good?
  9. Metalman
    On the subject of changing oils, my R56 manual is filled "lifetime" OEM oil. So what's the consensus of changing out the manual transmission?
    There is no such thing as non degrading "lifetime" oil. Or, is MINI, on the second generation, using some type of "better" oil?
    I understand the need of getting rid of all the loose metal particles that are attracted with magnets and draining the oil and replacing with new. And if so, what would the frequency be for a manual transmission? It doesn't seem correct to keep the original oil in for a lifetime.:nonod:
  10. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    The first Gen MINIs is OEM filled with a similar if not exactly the same 'lifetime' oil. I have a thread in the Track Talk section concerning track duty oil changes. But I am sure that many street only used cars go with 50k intervals, or even never.
  11. Metalman
    Thanks!
    I can't seem to find your section on Track Talk and oil changes. Where should I look? Couldn't find it in the library?
  12. mini_racer
    Engr Manager
    Oops, my bad.....different forum.
    [ame=http://www.metroplexmini.org/forum/showthread.php?t=28577]Track Duty Oil and trans fluid change interval - MetroplexMINI[/ame]
  13. Metalman
