Brakes Wheels 1st Gen Tires Valve stems aren't forever
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by nabeshin, Jun 26, 2009.
  1. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    Hey, just a friendly reminder to anyone getting new tires. Make sure that the techs actually replace all the valve stems. Stand outside the garage and eye them if you have to.
    When I got my tires mounted a week ago, 2 guys worked on them. The first guy only mounted one tire and apparently forgot to change the valve stem. The other guy finished up and changed the remaining stems.
    Today, my right front goes completely flat, almost instantly. Turns out that the one valve stem that was not changed failed. I missed my summer classes because of it. My sister had to bring me 2 of my winter tires and the jack & wrench. I changed out the front two tires so that I could drive safely to the tire shop. They got me fixed up with a new valve stem in about 10 minutes.
  2. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    Wow - tough one dude. Good to hear the tire didn't get wrecked.
    Alan
  3. ScottinBend
    That's why I carry a few valves with me in the car along with my plug kit and compressor.......:D
  4. Deviant
    Deviant Banned
    Student
    Southern IL
    It may just be hearsay but a tech at a local shop was telling me he was seeing an unusual high number of valve stem failures and theorized there was a bad batch from China, I myself had one fail last summer but luckily the dealer in Jacksonville, FL replaced it for me quickly, I need to get a few spares to carry around myself though.
    It's true. There are millions of bad valve stems out there.
    See Valve Stem Advisory - Discount Tire
    and
    http://www-odi.nhtsa.dot.gov/recalls/results.cfm?rcl_id=08T018&searchtype=quicksearch&summary=true&refurl=email
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #6 Nitrominis, Jun 26, 2009
  7. Deviant
    Deviant Banned
    Student
    Southern IL
    It involves a can of WD40 and a lighter. :eek6:
    [ame="http://www.youtube.com/watch?v=t7FIvAw2wC4&feature=related"]YouTube - Repairing a wheel using butane-gas and a lighter[/ame]
  9. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #9 Nitrominis, Jun 27, 2009
  10. FERNO
    FERNO New Member
    May 24, 2009
    53
    One of my buddies used to carry around a schrader tool with his keys. Used it for revenge.
    Someone he knew tried to bully him in a bar, so he when he left, he just loosened the the cores enough to give the guy an annoying and unpredictable leak, whereas for weeks he would walk to the car and find one or more tires low on air, depending on how he parked.
    Another time, someone parked behind him at a party and he asked them to move the car before they went to sleep because he had to go to work the next morning. As I'm sure you know, they didn't move the car. The next morning, he had to drive through the yard and a ditch to get out. Once he finally got out, he parked, walked over, and removed all 4 cores from the guys car. 10 hours later when Scott left work, dude was still stranded. He put the cores back in, but nobody ever parked behind him again.
  11. Deviant
    Deviant Banned
    Student
    Southern IL
    That's so much better than the juvenile slashing of the tire, you can see a slash. For weeks my mom used to put a few drops of oil under her bosses car, no revenge, people in my family are just evil like that.
  12. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    Thanks for posting. I was not aware of this!
    I did notice that my wife's new tires do indeed have new stems. :Thumbsup:
  13. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    Taking out the valves for revenge/mischief sounds hilarious.
  14. ScottinBend
    Wow........where did I say anything about changing the VALVE STEM.....
    :eek:ut:
  15. paulgraz
    paulgraz New Member
    Jun 18, 2009
    70
    IT Manager
    Howell, NJ
    I had a tire valve fail recently on my wife's car. The side cracked open - air release was rapid! A local shop replaced it and balanced the tire for free - but that's probably because I just had her car in there for a new clutch...
  16. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #16 Nitrominis, Jun 29, 2009
  17. ScottinBend
    Hmmmmmmm
    I say valve and you turn it into a question of valve stem. I correct you and you still don't get it.
    wow...
  18. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #18 Nitrominis, Jun 29, 2009
  19. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #19 Nitrominis, Jun 29, 2009
  20. Nathan
    Ok, you guys are just getting terminology confused.
    The vast majority of people when you say tire valve will think of the entire valve stem assembly and not of the of the actual valve encased within.
    Let it go please.
