Brakes Wheels 1st Gen Tires Valve stems aren't forever
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by nabeshin, Jun 26, 2009.
  1. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #21 Nitrominis, Jun 29, 2009
  2. ScottinBend
    Poor Lynn.......
    I assumed the OP was referring to the Schrader valve not the valve stem as failing. Thus I was trying not to confuse the issue anymore than necessary.
    I see it didn't work for you. :blush2:
    I love your sig addition Nathan!
  3. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #23 Nitrominis, Jun 29, 2009
  4. paulgraz
    paulgraz New Member
    Jun 18, 2009
    70
    IT Manager
    Howell, NJ
    #25 Nathan, Jun 29, 2009
    Can we give it rest now please...
    When getting new tires one should always opt for new valve stems unless such as the one pictured below that is standard in a Works Wheel VS-XX.
    To clarify
    BTW, isn't my new Screen Cap tool pretty nifty...those circles and arrows are so easy to place and use...
  6. ScottinBend
    :Thumbsup:
    Thus the reason I carry spare valves in the car. As the valves can get damaged while changing pressures at the track.
  7. AllBlack05S
    AllBlack05S New Member
    May 18, 2009
    66
    Selling Harley parts worldwide
    Bartlett, Il
    I like the oil drops under the car. I think taking it a bit further and squirting some on the lower skid plate at a seam would make it even better.
  8. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    I was talking about the big rubber exterior part of the thing, as Nathan points out - the valve stem. They showed me the valve stem after they took it out, the rubber was all dry and cracked. There is a good chance that the previous tire shop (a different one) didn't change it out.
  9. ScottinBend
    WOW.......now that's something I would be getting upset about.
    Clears things up a bit too :lol:
  10. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #30 Nitrominis, Jun 30, 2009
  11. ScottinBend
    Oh......so now were just clarifiers huh? :D
  12. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #32 Nitrominis, Jul 1, 2009
  13. Deviant
    Deviant Banned
    Student
    Southern IL
    Am I the only one who uses BW on that and occasionally treats it with a bit of tire dressing? I agree it should be replaced with the tires (since even if you treat the outside the rubber inside it is still drying out).
  14. paulgraz
    paulgraz New Member
    Jun 18, 2009
    70
    IT Manager
    Howell, NJ
    A second valve failed on my wife's cooper (within a few weeks of each other). The PO replaced the tires, I'm thinking that his tire shop did not replace the valves...
