2nd Gen R56 Cooper S Very slight clicking from the engine bay
Discussion in '2nd Generation: 2007+ R55 through R61' started by tmancoopers, Sep 26, 2013.
  1. tmancoopers
    tmancoopers New Member
    Sep 21, 2013
    21
    hey everyone!
    still loving my new mcs but ive noticed the faintest clicking sound coming from the engine bay. any ideas? im hearing a lot about a tensioner issue...at what point does it ABSOLUTELY need to be changed. cuz i just bought the car and im not exactly interested in spending more money on a repair already. that is IF its the tensioner
    any ideas,clues and suggestions would be much appreciated
    Since you have an R56 I doubt the tensioner is the problem. They seem somewhat more problematic on higher mileage R53 MINIs.
    The R56 being direct injection tends to make a clicking sound. That's a guess on my part.
    If it was the tensioner you'd hear what sounds like a diesel engine on a cold startup.
    Most likely you hear the fuel injection.
  4. Zapski
    Could also be low oil. We burn through it pretty quick.
  5. tmancoopers
    Sep 21, 2013
    21
    I'll check the oil level ASAP.
  6. tmancoopers
    Sep 21, 2013
    21
    Definitely doesn't sound like a diesel. Just a small click. I just feel no one else's engine makes that noise but mine LOL
  7. Xcmtber14
    Xcmtber14 Member
    Oct 12, 2013
    36
    9
    I also noticed a ticking today on my Mini. It sounds like it's coming from under the passenger wiper blade, where the battery is almost. The ticking speed stays constant regardless of engine rpm.
  8. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    I hear this electrical tick on every cold startup then goes away after a few minutes. You're dead on accurate on where you say the sound is coming from, I've even said it sounds like it's below the brake master cylinder/firewall area. I also sounds like an electronic solenoid or a coil spark, been hearing it for seven months with no ill effects.
