1st Gen R50 Cooper Weird noise coming from the front
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by drabdub, Jan 1, 2013.
  1. drabdub
    drabdub Well-Known Member
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    so i have this horrible noise coming from the front passenger(us) side of the car when im driving. it starts up at 30mph and sounds horrible after that. it almost sounds like i need to shift but thats not it.
    here is a video if it helps.
    [ame=http://www.youtube.com/watch?v=7z_0ctOf6zU&list=UUsujQ-vXfST_e_AOfyKQaPQ&index=1]GOPR0320 - YouTube[/ame]
    it makes noise except when going right which i find weird as well.
    do any if you have an idea of what to check or what it may be?
  2. drabdub
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    its not the rattling noise cause that is the go pro mount
  3. lotsie
    stagehand/part time detailer
    Right here
    Could be the axle is bad. Had to change out the right front axle on my 03 last year.
  4. drabdub
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    It's a brand new race axle from way with less than 1000 miles on it so I hope it's not it. Is there another way to check to see if it is?
  5. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Your wheel bearing is bad. I can't hear from the vid, but the tell-tale is what you said about the sound going away while turning right, and the noise becoming apparent at higher speeds.
    I don't think it is your axle. My money is on Eric, wheel bearing. Turning puts a load on the bearing & make the noise go away or change.
  7. Dave.0
    #7 Dave.0, Jan 2, 2013
    ^^^^ Yup, Eric is right. This was the same problem I had and new wheel bearings fixed it. :Thumbsup:
  8. drabdub
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    Is there a way to verify before I rip the car apart?
  9. philly_stan
    philly_stan Member
    Aug 19, 2012
    42
    ^^**What Eric and Dave said... I had the same noise and a new wheel bearing fixed the problem. Thanks again Eric (and Mike) for the swift repair service!
