Were there any other sizes of carbs used other than 1 1/4" and 1 3/4"??
Discussion in 'Classic Mini' started by ImagoX, Dec 23, 2011.
  1. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    So I'm taking my carb apart and measuring things for a K&N air filter but I have a problem...
    The carb I have LOOKS like a HIF-style unit (flat-bottomed with throttle and choke levers predominantly on the side of the body, etc.) but when I measured the main air intake opening it's precise 1 3/8" and NOT the 1 1/4" or 1 3/4" offered in either of these two units:
    HIF6 (1 3/4" opening):
    HIF6 HIF44 REBUILT CARB INLET MANIFOLD W/LINKAGE 1 - Classic Mini Cooper
    HIF38/HIF4 (1 1/4" opening):
    1 1/2 HIF38 HIF4 SU REBUILT CARB INC. MANIFOLD & F - Classic Mini Cooper
    So far I've tried three different units from K&N and NONE fit, and I'm starting to wonder if someone bolted a non-Mini carb onto my car when they converted it from SPI. :confused:
    Any ideas???
    PS - this is the only identifying mark I can find on the unit - this is inside the top pot assembly:
    There's also a "06" (or maybe a "90") cast into the side of the main body.
  2. Minidave
    Where are you measuring?
    Measure at the throttle plate and let us know what you get....
  3. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    The opening where the air filter bolts to the carb.
    The opening where the SU mounts to the intake manifold.
    Did you know SU stands for Seemingly Useless. Not really, just one of the many Brit car jokes I've heard over the years. :wink:
  5. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    It's a 1.5" then, measuring the OUTPUT side. My car's lack of pick-up is now explained. :) Now the question is: Can I find a proper 1.75" unit without having to sell a kidney?
  6. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    #6 ImagoX, Dec 26, 2011
  7. paulsminis
    paulsminis New Member
    Contractor to the Government
    Dayton, Ohio area
    Seven's rebuilt set is a fair deal. And I mentioned on your other thread that I have a used LCB exhaust.....
  8. TA2DMAC
    TA2DMAC New Member
    Nov 16, 2010
    6
    Take the Number from the carb (eg.HS2) & put that number over 8 = 2/8 . Lowest common denominator of that is 1/4. Add this fraction to 1 & bingo you have the internal measurement. HS2 = 1+2/8 = 1 1/4", HS4 =1+4/8 = 1 1/2", HS6 = 1+6/8 = 1 3/4" etc
    Similarly the HIF range are quite easy to figure out HIF38 = 38mm. 1" = 25.4mm. Therefore 38/25.4 = 1.49" or 1 1/2".
