What are people running for ignition coils?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by beken, Nov 20, 2018.
  1. 00Mini
    That’s a good question and I don’t believe I have ever seen an answer to it.
  2. Scavenger
    Scavenger Active Member
    May 11, 2009
    62
    Apex, NC
    Yes, I have seen others post the same thing, I'm not sure why.
    • Like Like x 1
    • Agree Agree x 1
  3. MCS02
    The answer is very complicated but I will try and answer. See on the second full moon of each lunar cycle when the temperature is in the mid range the mini gnomes come out. They usually inspect your mini to make sure all is in order. See the problem is that this takes a long time. By the time they get to the coil pack they need to relieve themselves. They do this on the coil pack to see if it is getting fire, and as you know the #3 connector does not put out as much power so they use that one. So gnomes forget to clean it off there by causing rust.
    Now you know
    • Winner Winner x 2
    • Funny Funny x 1
