What are the best 10mm spacers to use on all 4 corners
Discussion in 'MINI' started by olerodder, May 11, 2017.
  1. olerodder
    olerodder Member
    51
    Sold manufacturing automation most of my life, as
    Pacific Northwest
    What should I torque the bolts to with the spacers. I have them 100 lb ft now and was thinking of using loctite on the threads...any suggestions as these of the first spacers I've use in 60 years of motoring.
  2. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Just the standard 103.whatever it is will be fine. No need to use loctite.
    My .02 is that spacers introduce a failure point. If one wants that look of wheels sticking out farther I'd recommend buying wheels with the correct offset to give you that look. Again justa my .02 & worth every penny. :wink:
  4. olerodder
    olerodder Member
    51
    Pacific Northwest
    These are factory JCW Mini wheels. I have the OE retrofit kit for limiting the steering and rather than limit steering travel I used 12mm spacers.
    Just for information...as I'm a retired mechanical engineer...it's not the spacer that introduces the failure point, it's the lugs that fail...hence 38mm lugs which are longer to account for the 12mm spacer.
    If you were to buy cheap spacers like on Epray I suppose if they didn't have the ring to mate to the OE Mini wheel or the ring to mate with the hub you could have movement and break studs and the studs could fracture the spacer...you guy cheap stuff and stuff happens, especially on suspension parts.
    Just thought you would should know it's the lugs that take most of the moment of force, not the spacer.
    My wheels and tires do not stick out beyond the body.
  5. Dave.0
    Turner has the correct bolts listed by spacer thickness.
    SILVER BOLTS: https://www.turnermotorsport.com/p-338601-wheel-bolt-12x150-silver-for-most-1975-2012-bmw-minis/?pdk=Eg
    BLACK BOLTS: https://www.turnermotorsport.com/p-338594-wheel-bolt-set-12x150-black-for-most-1975-2012-bmw-mini/?pdk=AQ
    Standard/Stock Size (#TWH995128B) ($27.50) 1
    Bolt For 3mm Wheel Spacer (#TWH995128B) ($27.50) 1
    Bolt For 5-8mm Wheel Spacer (#TWH995132B) ($28.90) 1
    Bolt For 10mm Wheel Spacer (#TWH995135B) ($29.50) 1
    Bolt For 12mm-12.5mm Wheel Spacer (#TWH995139B) ($29.50) 1
    Bolt For 15mm Wheel Spacer (#TWH995143B) ($29.50) 1
    Bolt For 18mm Wheel Spacer (#TWH995143B) ($29.50) 1
    Bolt For 20mm Wheel Spacer (#TWH995145B) ($29.50)
    No way I'm going to contradict what an engineer has to say. What railroad did you work for? :biggrin5:
  7. olerodder
    olerodder Member
    51
    Pacific Northwest
    Worked for a branch of the government..."if I tell you then I'll have to #*-- @$%".
  9. olerodder
    olerodder Member
    51
    Pacific Northwest
    Picture of the Clubman S
