What are you doing to your MINI before the Dragon?
Discussion in 'MINIs on the Dragon 11 (May 1 - 5, 2013) - TN / NC' started by CHKMINI, Mar 29, 2013.
  1. AAONMS
    AAONMS Well-Known Member
    5,027
    221
    I play with trains...
    Fruit Cove, FL
    Mine:
    Oil and filter change
    Renew coolant
    Flush brakes
    Rotate/balance tires
    Wife’s:
    Flush brakes
  2. CHKMINI
    Full paint detail. I've clayed, machine polished, sealed and now finishing up with black wow. Dark Helmet's exterior is ready. Now for the other bits that need installed.
  3. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Who did you have do the clear bra?
  4. hanyssa
    hanyssa New Member
    Jun 6, 2012
    342
    91
    Automotive Appearance Pros
    aapcolumbus.com
    Dave did my custom graphics too. They do great work.
  5. BlimeyCabrio
    Brake flush
    Paint touch-up
    Install summer wheels
    New chain tensioner
    Secure battery a bit better
    Detail in and out
  6. ChefTyGuy
    ChefTyGuy New Member
    Feb 17, 2013
    6
    i've got to take delivery and break in my new boy before the trek from Florida. Also have lowering springs, RSB, lower control arms, rear end links, PULSAR, Smoked side marker tint, Badges galore, and maybe a hanging pair of fuzzy dice =p
  7. SNEEEZY - Erika
    1,212
    116
    Female
    Head gasket...possible cylinder head...YIPPEE!!!
    Oil change (part of the head gasket/cylinder head stuff...)
    Coolant flush (part of the head gaskey/cylinder head stuff...)
    Brake fluid flush
    New wipers (sorry, but the Silblades didn't last long at all)
    Top of washer fluid levels
    Detail the interior (to include removing, cleaning & reinstalling the Wet Okoles)
    Claybar, polish & wax the paint
    New tires
    Replace the strut portion of the Megan Coilovers on all four corners
    Lube the rear swaybar via the zerk fittings (love those!)
  8. smurfette26
    smurfette26 Club Coordinator
    Nov 1, 2010
    109
    Do you use the dealer touch up paint for touch ups? I found that it looks really bad on the Cool Blue. I have tried various other things unsuccessfully.
    New dancing shoes for Skooby the clubster.
  10. wmwny
    4,040
    2,242
    New brake fluid should help the S get thru the twisties.
    ^^^ Can't be too careful. :Thumbsup:
  12. 05r50
    Dec 4, 2010
    1,269
    696
    Lets See.......
    1. Powder Coat wheels - Done
    2. New Tires - Done
    3. Spark Plugs
    4. Air Filter
    5. Transmission fluid change
    6. Drive Belt
    7. SS brake lines and fluid change
    8. Install JCW front Aero bumper
    9. Lots of cleaning
  13. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    well so far I have installed new IE camber plates, changed drive belt (really can't believe it wasn't slipping yet last hole on the tensioner you could only see half of it), 5mm spacers, converted to wheel studs, on the list of things to do...
    Install wilwood BBK
    Brake fluid flush
    Lube rear caliper sliders
    Rotate tires
    Get alignment in the front checked
    Change IC boots
    list of possibles due to time or mileage
    oil change (only about 2k into the current cycle, will be around 3500 at the dragon)
    full clay bar wash and wax
  14. BlimeyCabrio
    Sorry - just saw this.
    Nope, not the dealer paint.
    I've tried a few different sources. The only formulation I've found that looks decent is Standox. It's the OEM-spec paint, as I understand it, or really close. Available from Finishmaster and some other pro paint suppliers. The 3M color that is supposed to be the same, isn't even close.
    If you go to your local Finishmaster, or find another Standox supplier or someone who does small touchup quantities using Standox formulation, and order Mini Cooper Cool Blue, it will be very, very close. You'll still need to apply it properly, and use clear coat properly, and blend it properly using something like Langka. Or wet sand / buff if your a pro and know what you're doing. But don't call me if you wet sand through your paint. :)
  15. Savvy
    So far I have replaced the following:
    Belt
    Belt Tensioner
    oil pan gasket
    crank sensor seal
    vinyl-deleted the sunroof
    Need to do:
    install the R53 JCW brakes I picked up
    mount the summer tires onto the summer wheels
    Joey mod the xenons
    black out the belt line
    black out the headlight rings
    get the rear glass tinted
    oh, yeah... and DETAIL THE $#!+ out of it.
  16. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Welp the mechanicals are finally all sorted...
    Still needed:
    Brake Fluid Flush
    Finish Brake Cooling Ducts
    Full exterior detail
    Install Gang Stripes
    Few other small bits if I get time
  17. Snooter
    Snooter Club Coordinator
    273
    Canton, NC
    Think we are finally done Modding Spider. Since we got him a few months ago, we done the following:
    Painted the Arches to match the car
    Painted and installed JCW side skirts
    Blacked out the Belt Line
    Blacked out the Rear Lights trim
    Blacked out the Front Lights trim
    Blacked out the Front Grill trim
    Added Stripes
    Custom two tone leather seats
    Painted the interior door rings
    Painted the interior center dash
    Paint the door handles
    Painted the Side Scuttles
    Painted the rear chrome roll bar covers
    Powder coated the rims
    Just need to replace the white lights covers on the side scuttles and we are good to go!!
  18. Dave.0
    Unfortunately I just had to add a new Alternator to my list. :mad2:
    Well at least it is done now and did not fail on the way too or on the Dragon.:Thumbsup:
    Great catch by the guys at Helix while doing my PreDragon inspection / tune up.:Thumbsup:
  19. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    DaveO - my alternator failed at the Overlook two years ago on the Saturday afternoon ending the Dragon!
    The Mini is programmed to sequentially shut down electrical components to protect the running engine, and one of the highest-draw items is... wait for it... the POWER STEERING! I swapped batteries with a riding companion, and drove back to Fontana with no power steering - and the Mini is designed to always have power assist (it's not like a Miata or Rabbit where the geometry allows no p/s and easy steering at speed). Felt like Chuck Norris when I made it back!
    Thankfully, can't say enough about Hendricks Mini, who had one of "their guys" coming out from Charlotte that evening. They got ahold of their parts guy, who grabbed an alternator, and they hotshotted it out. I got it at 130AM, and the car was running on the new alternator by 330AM, drove home on it the next day and haven't looked back! (don't ask what a factory alternator cost 3 years ago, with hotshot shipping, but it was altogether cheaper than missing 2-3 days of work and staying in a hotel!).
    For me?
    - Konis/springs/plates (that's the biggie!)
    - ebrake cable (PITA repair!)
    - tie rods (corroded and can't be adjusted!)
    - Rear rotors
    - another Group4Autosports exhaust prototype!
  20. wmwny
    4,040
    2,242
    Complete pre-trip going over at MAG for the MC-cvt, including new brake fluid.
    Replace rear struts and tophats on the MCSa.
    Whichever car gets done first is the one I'll bring to MOTD.
