  1. Metalman
    Looks good Jeff..... Ahhhhh, what's that dangly green wire in the second picture?
  2. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Scrap wire I used to hold the caliper out of the way.
  3. Metalman
    Woarshed the MINI..... Picking glue off the door sills..... Going out to get some Goo Gone....
  4. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    #2284 Friskie, Jun 10, 2012
    That's how I pronounce it too and my wife won't let it go. Thanks for the confirmation. Solidarity? (Learned if from a real good friend who lived in Seattle, Woarshington making him the authority).
  5. Metalman
    Yeah..... "Woarshed the MINI" sounds like I'm really getting it cleaned..... Much much cleaner than simply..... "washed the MINI"....:Thumbsup:
  6. Mr. Jim
    Met with the "Drive n Eat" Crew, 8 MINI's and a great drive through west central Jersey crossed the Delaware into PA for some great lunch and ice cream!!
    Thanks to JohnW for the great drive today!
  7. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    My pleasure :Thumbsup: Couldn't ask for better weather too.
    Gave both MINI's the day off. We took the Not N MG for a romp on the back roads. Ice cream at the Old Mill in Utica. :drool
  9. 05r50
    Dec 4, 2010
    1,269
    696
    So, I noticed that the pasenger rear brake does not seem to be bedding in like the others. Spent most of the day over at a friends house trying to get this brake corrected. (It's good to have a friend with his own lift at home :biggrin5:)
    What I noticed is that the outer edge of the outside of the rotor is wearing the coating off, while the inside edge of the backside of the rotor is also the same. You can kind of see the outer edge is wearing but not the entire face.
    Seems to me,
    1. The line might need bleeding? (didn't have time to bleed and replace lines today)
    2. The caliper is not working correctly and therefore the pads are not making contact.
    3. The rotor is warped and the pads are not going to make full contact and wont until they wear down.
    My buddy took the car out for a little road test and pulled a couple of hand brake stops and could not get the right rear to lock up but the left did.
    Any other thoughts?
  10. Little Wing
    Little Wing New Member
    Sep 7, 2009
    340
    72
    Tallahassee, FL
    Washed (regular pronunciation, but did a good job) Little Wing around dawn.
    Motored to Jacksonville.
    Washed Little Wing again, but it was quick and easy.
    Joined the Jacksonville Area Mini Motoring club at Tom Bush Mini for the sponsored event "Take Mini to the Ball Game."
    Watched the Jacksonville Suns beat the Jackson Generals twice!
    Yay Suns!
    Wet, muddy conditions prevented our planned Mini parade around the field.
    That was a good thing in retrospect.
    All the cars would have needed another wash immediately.
    We still had a great time.
    Many thanks to Tom Bush Mini for their support of the Mini community! :Thumbsup:
    Thanks too for the great food.
    Fun day!
  11. alwzopn
    alwzopn New Member
    Jul 1, 2010
    183
    Swapped out my cabrio's third brake light for a white one - before and after:
  12. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Looks great! :Thumbsup: Anyone know if there is a version for R53s?
  13. alwzopn
    alwzopn New Member
    Jul 1, 2010
    183
  14. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Just found it on Outmotoring as you posted that! Thanks!
  15. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    After a lot of patient and a few curse words, I was able to install my Alta intercooler couplers.
  16. alwzopn
    alwzopn New Member
    Jul 1, 2010
    183
    I had to give up after wrestling with the small side for 30+ min. The large side was easy; the small side was so tight it was shaving silicone bits off as I tried to fit it.
    Using the recommended bent awl tool, I could (eventually) get it on either the engine side or the intercooler side, but never both at the same time.
  17. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    I ending up shaving off some of the silicone on the small coupler, boiling it for about 7 minutes, and putting a little engine oil on the inside of it to get it on. I think the toughest part was getting everything back together. I didn't have a bent awl so a mixture of some other tools had to suffice.
    Glad they are on though!!
  18. Nathan
    Hate to say it folks, but those fancy silicon I/C boots...yeah, in the long run you'll probably be back to OEM. Been there, done that.
    +1 ^^^ :frown2:
  20. KittyMini
    KittyMini Club Coordinator
    1,183
    I drove my car to work in the rain :eek6:
    I know.... crazy! :lol:
