    10,049
    Why yes the Here still works too. Don't know how I missed that, well yes I know. :eek:
    A guy that I know had a 63 AC Bristol that he bought new as his first car, it is a beautiful original. He sold it a few years ago as it was time for someone else to be the steward of the AC. The new owner took it to the Pebble Beach Concours & even flew my friend out to California so he could be with his pride & joy for its moment in the spotlight.
  2. SacredDisorder
    SacredDisorder Because Race Car?
    209
    54
    Iott Ranch & Orchard
    Petersburg, MI
    Finally installed the new mud flaps front and rear.
    And test fitting the new shoes. Need to figure this out. This is without the 5mm spacer it will need.
    What to do, what to do.....
  3. KittyMini
    KittyMini Club Coordinator
    1,183
    I hit a raccoon this morning on the way to work :frown2:
    SOMEHOW I have no damage?????? :eek6:
    I need to jack up the car to verify, but if the front bumper (which is the lowest part of the car) is fine, then I'm gonna assume the rest is ok? :fingerscrossed:
  4. SacredDisorder
    209
    54
    Petersburg, MI
    Good Luck! hope all is well under there!
  5. ljmattox
    ljmattox Active Member
    Dec 28, 2011
    223
    123
    IT consultant
    St Louis metro USA
    Replaced my Belkin bluetooth solution with a similar Kinivo unit (BTC450). Streamed music quality is fine, perhaps a slight improvement, and it auto-connects when I enter the car, a definite improvement.
  6. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    I find it hard to believe there was no damage...... To the raccoon :)
  7. KittyMini
    1,183
    I think I took that poor thing out :frown5:
    Sucker was big, too.
  8. Jason Montague
    :cornut: Most of y'all know the story of my '35lb Raccoon Swan Dive Suicide Leap' under the right front bumper of Margi(08 R56 Brg MCS/JCWm) ~ Mar 2012 at night at 65mph. It took out the radiator, oil cooler, AC condensor, Inter cooler, front bumper, right parking and fog light, And I can't remember what else. Total cost $5,000.00. Life goes on.:Thumbsup:
    10,049
    #4129 Crashton, Feb 6, 2013
    ^ Sorry to say but those R56 MINI's just aren't as tough. :wink:
    Monica be careful. I hit a squirrel & not 10 miles later my alternator went all FUBAR on me.
    I think squirrels last act was to evoke a spell from Joseph Lucas. :)
  10. Tata Steva
    May 30, 2010
    407
    229
    DOP/stock Photography
    TO
    Today, I went to my garage and let my PEPPENSALT know that i keep her colors high against the competition in MINI OF THE MONTH contest...
    Go PEPPERNSALT!
    :biggrin5:
  11. Jason Montague
    :cornut: Groceries, Pharmacy, Coffee Klache, Fuel Up and check fluids/tire pressure. That really took it out of me, the air temp was 63f.:Thumbsup:
  12. Mini813
    Mini813 New Member
    Dec 5, 2012
    27
    16
    Warehouse Manager
    Tampa FL
    I love the GP so I got my mirrors painted on chilli red. Love the look.
    21AC87FB-91FE-48EA-9B63-6E218EEBC266-2688-0000021363E862C6.jpg 498DECB4-507B-4C32-A99B-ADA1A7F2311E-2688-000002137937D50D.jpg
    10,049
    Washed Skooby for Babs. Cleaned the windows on Blu Brit & drive out for pizza with local MINI friends.
  14. Justa Jim
    What....you mean you didn't change the oil in both of them??????? :D
  15. T8rChick
    T8rChick Active Member
    111
    Oak Cliff, TX
    Took Daphne to MINI of Dallas for an oil change and state inspection! And got a hug from a lovable MINI tech!
  16. Firebro17
    #4136 Firebro17, Feb 6, 2013
    Rear Wiper Delete
    As a follow-up to my entry a few posts ago, here's a couple pics of the rear wiper delete I just did on my '05 R53. This is pretty much an elementary task that was completed in less than an hour, including beer. All the parts were purchased at the local Ace Hardware for less than two bucks (not including paint and silicone). Here's a suggested parts list and the steps I took to do the job...
    1 - 1/4" plastic plug
    1 - 1/4" s/s allen cap screw
    1 - 1/4" s/s nylock
    1 - 3/4" s/s fender washer
    1 - 1" s/s fender washer
    Remove the rear wiper arm from the car. You may have to use a puller to break it loose from the shaft. (Remember to remove the small plastic nozzle from the brass washer tubing first! I didn't...) Remove the rear hatch panel and remove the rear wiper motor. Plug the rubber window washer hose using the 1/4" plastic plug, sealing with clear silicone. Tie the power wire and rubber hose to the hatch with a couple of small zip ties. Drill out the holes in the washers to accommodate the 1/4" screw. (Most all fender washers this size will have a smaller and more proportionately correct hole in them) Paint the 3/4" washer and cap screw with flat black paint and allow to dry. (I used Duplicolor DA 1605 Flat Black) Assemble and seal the 1" inner washer to the OEM rubber grommet with a liberal amount of clear silicone and set aside to cure. Once all the parts have cured and dried, fit the cap screw and 3/4" outer washer (painted) into the rubber grommet, tightening the nylock nut just enough to keep from distorting the grommet. Re-install the rubber grommet in the rear glass, then re-install the plastic trim panel on the rear hatch.
    Sorry 'bout the picture quality. I guess the iphone wasn't all that great here... Anyway, hope this helps some of you wanting to take on this simple mod. Contact me any time if you need any help. Well, except for next week..... We'll be in Hawaii..... :beer
  17. Crashton
    10,049
    Here's an oil change for you Jim. :Thumbsup:
  18. drabdub
    drabdub Well-Known Member
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    noticed a dent in the hood on the pink one... almost cried.... time to get some new bumpers for the front and back then a respray and blend
  19. Dave.0
    Drove to work and back today. Driving home was more FUN.
  20. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Had the idler pulley replaced -the bearing came apart when the pulley was removed - so 156,322 miles and almost 10+ plus years - not too shabby!
