  1. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    Well, you got all your money's worth out of that filter...
  2. pmsummer
    pmsummer Well-Known Member
    Apr 3, 2012
    570
    400
    Semi-retired planner
    I replaced the sensor (even if I had replaced the pads and rotors before waiting for the sensor to wear down, there is NO WAY I could have removed the old one without destroying it), and I'm going to double-check the connection today.
  3. pmsummer
    Apr 3, 2012
    570
    400
    Haz mat!
    Fixed the loose nut that was allowing the right side mirror to flop over at speed. Thanks for the help to the person that happened to have a 19mm open ended wrench handy.
  5. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    Watched it get a shower from nature. I miss my garage :(
  6. Metalman
    Today I helped a person, that happened to require a 19mm wrench, that was needed to tighten a wayward nut, on their MINI... :Thumbsup:
    Even if it was an R53.....:D
    Was the loose nut behind the wheel? :crazy:
  8. Dave.0
    Today I took a nice ride to Jersey with my wife and like always you have to pay to leave Jersey. :lol:
    It was a good drive.
    Gave my MINI a nice workout today, cool & damp made much power. Fun fun fun. :D Payed no tolls. :wink:
  10. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    Drove out to Newport Oregon and back to the valley. We are having super weather right now. Lots of curves and beautiful scenery to enjoy in the coastal mountain range.
  11. RussWK
    Apr 1, 2011
    106
    61
    I look at the revolutions per mile, which for my R52 makes the speedometer fairly accurate at 830 revs per mile. My current tires are 215 x18 on 8 inch wide rims. They don't rub except on hard bounce in the rear. The outside of the tire hits the inner edge of the plastic fender flare.
    http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Primacy+Alpin+PA3&sidewall=Blackwall&partnum=055HR6PRPA3V2&tab=Specs
    This tire rack shows a Michelin 205x55 R16 snow tire with 835 revs per mile. I would think that would be close to stock.
    A 225/50x16 will fit a 7 inch rim and would be 835 revs per mile. Its a wide tire though. but probably won't rub if it is centered. Maybe go with a 215 55x16 - it has a 826 Rev per mile, and a little wider section width, but close to the same tread width - about 7.5 inches. But it is a bit taller and could rub a tiny bit. So to be safe, maybe stick with a 205.
    Take more than a 19mm open ended wrench to tighten this nut.
  13. DryMartini
    DryMartini New Member
    Dec 6, 2012
    1,048
    479
    It's nice and sunny after some rain. So, Herself washed and "Hoovered" it. Going gambling tonight, so we might as well arrive in a clean Bertie.
  14. Dave.0
    Wash and vac later today. I have to top off the Meth tank and take a FUN run to fill up with some Sunoco 93.
  15. Nathan
    Moved it from a Monday-Friday illegal spot to a legal one.
  16. GraceinAction
    GraceinAction New Member
    Oct 10, 2013
    30
    6
    healthcare
    Rhode Island
    Washed and "waxed" my car with Prima Epic while the weather is still reasonably warm in New England.
  17. Dave.0
    I ended up waxing my car after I was done washing it today.
  18. Savvy
    Noooooooooooooo..................... really!?
    I don't believe it. :p
  19. Dave.0
    I also ordered new front rotors, pads and SS lines for my JCW brake upgrade.
  20. wmwny
    4,040
    2,242
    Wooohoooo...THREE other MINIs joined my car and me at Mid Ohio this weekend! I could tell my S was THRILLED, even though the rain and 43 degree temps on Saturday made for some slooow driving. Today was sunny, warmer and a lot faster.
