  1. CHKMINI
    Took a nice drive down through the Hocking Hills brought DH back home and washed the road crud from him. A good day!
    Should have come on a drive to Amish country with Babs Tom & I.
  3. CHKMINI
    Last minute decision.
  4. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I changed the serpentine belt today.
    Good thing I did. The belt was dried out and cracked. Probably about to give out.
  5. ljmattox
    ljmattox Active Member
    Dec 28, 2011
    223
    123
    IT consultant
    St Louis metro USA
    Took care of a couple of service items.
    Did my first brake fluid flush, the first time I'd used my BavAuto pressure bleeder device. Made it darned simple.
    Drained and refilled the manual trans. At 47k miles, the original oil still looked very serviceable, really about like new. I went with RedLine MTL for the fill, having heard so many recommendations.
    And then swapped in my summer wheels/tires. Just in time for a winter storm front that's passing through today!
  6. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    #6446 RussWK, Mar 16, 2014
    Went to Portland and back freeway going and back roads coming back. Still trying to decide whether to install DT Bypass valve. I looked at a new one at dealer, and it shows light all around the butterfly. Probably the way mine would be. The DT shows no light. But how much boost are we losing? Maybe not much. Car makes 197 WHP with RMW dyno-tune, 15%, CAI, Catback and stock injectors, cam etc. Driveability and mileage are concerns. Want to cure yo-yo that happens at certain times W/O sacrificing mileage and normal driveability.
    06 R52, Koni FSD, 15% pulley, CAI, DOS copper intercooler, ATI superdamper, RMW dyno-tuned, Pulstar Spark Plugs, MSD ignition and wires, upper and lower braces, under tower plates, Engine and lower control poly bushings, 22mm rear bar, 18X8 Signature Autobahn rims, Continental DWS 215x40x18. All Amsoil lube and fluids, PS Pump fan covered and ducted.
  7. ScottinBend
    I have an RMW tune and still get a bit of yoyo at part throttle around 2500-3000 rpm in second gear. I just make sure to be above about 75% throttle while in that range and all is good.
  8. Dave.0
    I put the big pipes on today and woke up the neighborhood with a test drive. :devil::Thumbsup:
  9. Apex
    Apex New Member
    Jan 19, 2014
    96
    NJ
    Checked the oil after running some errands today and heard a hissing sound; I look up and see some bubbles coming from the seam of the coolant expansion tank. I guess an aluminum reservoir is in my future?
  10. Nathan
    Dropped it off at the shop for it's pre-MOTD checkup and some other work. New fuel filter, new timing chain and all those parts. Change all fluids and general going over.
    Drove the shuttle bus/MINI to Best Motor Werks. Picked up good buddy Nathan & dropped him off at Motoring Alliance world headquarters. Good deed for the day done. :D
  12. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Personal Assistant and Merchandiser
    Port Orchard,WA
    D.B. drove me to work then after we went to look at car toys for a new stereo system... His speakers rattle and the stock stereo will have to go... Found the set up I want for a mere 2k...
  13. mrntd
    Add the short shifter and a custom cover, on the 3 try.
  14. teresa wood
    teresa wood Well-Known Member
    1,237
    761
    Arvada, Colorado
    An Anniversary gift from my better half
    Put my new M/A Year 1 decal on!:biggrin5:
  15. Firebro17
    Well, nothing unfortunately. I'm at the Coast and my Minis are tucked away at home.
  16. KittyMini
    KittyMini Club Coordinator
    1,183
    Woot! Drove it for the first time in a few weeks :Thumbsup:
  17. AAONMS
    AAONMS Well-Known Member
    5,027
    221
    I play with trains...
    Fruit Cove, FL
    Had it put on a tiltbed for a trip to the dealer.
    Dealer took great care of the car and me and I was on my way in a little over three hours.
  18. DryMartini
    DryMartini New Member
    Dec 6, 2012
    1,048
    479
    Went to Target to stock up on Diet Pepsi to support Herself's habit, then topped up with 93. A MINI ride, but full of smiles none the less! :wink:
  19. mattc85
    mattc85 Active Member
    Sep 24, 2013
    277
    222
    Heating and Air
    Mocksville, North Carolina
    I motored over to Sneed's Speed today and picked this up.
  20. DneprDave
    A night stick?
    Dave
