  1. Dave.0
    Oh dear God my eyes. :nonod:
  2. Savvy
    Drove up to the Innsbrook, VA Cars & Coffee this morning. Where this 100% original survivor showed up.
  3. minirab
    What a sweetie! :Thumbsup:
  4. Tallman
    Tallman New Member
    70
    14
    Auto Technician (VERY low experience)
    Okemos, Michigan USA
    Great assortment of photo's.....thank you so much for sharing!
    Would be a pleasure to cruise about in than vehicle :Thumbsup:
  5. Ujin
    Ujin Member
    Feb 22, 2014
    Simpsonville, South Carolina
    Put Angus on jack stands and checked the control arm bushings. May need to look into replacing these soon...
  6. c0op3r
    c0op3r Active Member
    Oct 2, 2013
    196
    133
    Mech Eng and IT
    Orlando FL
    Install JCW Projection Puddle lamps:
  7. wmwny
    4,040
    2,242
    Hmmmm...BAAAD day for me and my S at Mid Ohio this weekend...ran into some curbing and broke my lower front bumper. :mad5: These things happen when you "think" you are backing up, only to find the opposite is true. :mad2:
    Gee, is there a bright side? Well, my TSW lowered car is now "lowered" to around 2" off the ground...just great for upcoming track days...grrrrr, providing the freaking thing even stays on the car!
  8. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    $16.00 each plus shipping. About $75 for the set. We had a club run today from Portland, OR to Toppish WA. Since I came from Salem, my mileage today was about 460 miles. Beautiful run through the Columbia River gorge and up through Washington to Yakima Valley on winding roads. So, I have driven the Mini over 2,000 miles since Thursday a week ago.
    Yes, these new 5,000,000 watt Pulstar PlasmaCore plugs are the best yet. These are the newest version. I've been using them for 5 or 6 years on the supercharged Buick and now the Mini. I also used them on an old 64 Ford 6 Cylinder 170 CI engine, (had to use capacitor attachments to a standard plug) and could tell a difference in smoother idle and more power.
    On today's run I pulled most big hills in 6th gear from 2K RPM. You can tell there is more torque. And, when you shift down to 2nd or third, things really happen. I am also using the newest Amsoil 5W-40 full SAPS European Blend synthetic oil, which the dealer says BMW now recommends.
    Getting back to the plugs; you have to also be careful installing the plugs. DO NOT use a rubber sleeved socket, because the capacitor (which stores the 5,000,000 watt charge) is inside the porcelain body of the plug which makes the thin porcelain shell susceptible to cracking if you accidentally put side force on it while turning it in. So you have to lower the plug into the hole with a rubber hose,get it starting in the threads, and then use a socket that doesn't put accidental pressure on the porcelain while you tighten it to the normal torque.
    --Russ
    Sorry to hear this. If there is any way I can help PM me. :frown2:
  10. teresa wood
    teresa wood Well-Known Member
    1,237
    761
    Arvada, Colorado
    Someone posted about using his leaf blower to dry his MINI so we tested. It helps! uploadfromtaptalk1404092889989.jpg
  11. wmwny
    4,040
    2,242
    Hmmmm...EGAD...hope no leaf fragments were near that blower! I can just imagine the after effects of an "external walnut shell blaster type" dryer! :eek6::ihih:
  12. Firebro17
    #7452 Firebro17, Jun 29, 2014
    We raced at Mid Ohio!! What a blast that place is. You locals are awful lucky and thanks for the hospitality!
  13. wmwny
    4,040
    2,242
    You are always welcome to return. :Thumbsup: I KNOW you guys made a ton of friends there! :cornut:
  14. Dave.0
    This past weekend I drove all over and used lots of fuel and meth. :Thumbsup:
    No tickets.
  15. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Meth? :eek6:
    ...no tickets...yah right. Did you drive over the speed limit? :wink:
    That meth is a special blend for hypermiling. :lol:
    Drove Skooby to the grocery. Came back loaded with grub.
  17. Dave.0
    Yes, Yes I did. As a matter of fact tend to spend more time over it then under it. :ihih:
    May you continue to beat the odds Dave. :fingerscrossed:
  19. DneprDave
    Actually, the odds of getting a speeding ticket are pretty small.
  20. Nathan
    Turned 80,000 miles on the way to Cardiac Rehab.
