  1. BlimeyCabrio
    I might, when I'm done. Probably between 300 and 325. Of course, I could have had a Cayman S for what I'll have in the car at that point.
    The RMW turbo kit can make 320, and then some.
  2. Metalman
    This worked for me....
  3. Metalman
    Went down to the shop this morning...
    Replaced the rear discs and pads...
    I kept getting the yellow warning light that the MINI needed brake service.....
    Turns out the rear pads still had about a 1/4" of material remaining...:mad:
    Soooo apparently the way the brake sensor works is when the pads get to a 1/4" the sensor makes contact with the disc and is grounded... This gives the yellow warning.... As you continue to drive, eventually the sensor's copper wire is worn through and this breaks the circuit that then gives a red brake warning... IMHO, MINI is having the brakes replaced way too soon....
    I decided to disarm the sensor by removing it completely, soldered the two sensor wires together and covered the end with heat shrink tubing.... Reset the brake service warning light..... Done... It's not that big of a deal to check the pad thickness and I'll get more pad wear without the brake warning light being activated....:D
    Any day you can kill a nanny on your car is a good one. Well done Chuck well done!
  5. Metalman
    Chuck....You hep'd....:D
    And thanks!:Thumbsup:
    Couldn't have done it without the use of your special turney brake piston retractor screwy thingy... And the "pump em up" brake fluid pusher outer extractor...
  6. Chaz
    Chaz Member
    Mar 9, 2015
    35
    21
    Any reason why these come on together? Seems to come on after it's been washed or rained on. Airbag light always on so ignore that, just the other 3
  7. Firebro17
    Presto-Changeo. BAM!
  8. Boxman
    Boxman New Member
    Oct 1, 2012
    144
    34
    Technical Support Specialist
    Lebanon, Pennsylvania
    You literally have more lights on in your dash than a flipping prison has when an inmate escapes...
    Bad connectors or battery, or you might have the same problem I did and it's your ignition switch :ihih:
  9. MCS02
    Ok so did you know your steering wheel is on the wrong side?:devil:
    You may have a bad wheel speed sensor. That's what my mini did. It's usually the left front. Don't ask me why. But it could be any of them.
  10. MCS02
    I want a ride at the Dragon. But you should know I prefer to stay right side up.:arf:
  11. BlimeyCabrio
    Yep, that's called "the trifecta"
    Common problem.
    The wheel speed sensor is usually NOT "bad" per se... but a flaky wheel speed sensor signal is detected. Usually, disconnecting, removing, cleaning and reinstalling the left front sensor will resolve this.
  12. rlma84
    rlma84 New Member
    Aug 30, 2015
    6
    Installed halos lights on fog lights
  13. Chaz
    Chaz Member
    Mar 9, 2015
    35
    21
    #10853 Chaz, Sep 19, 2015
    Why? Lol seems like it could be that, if I do restart the car and drive a little it goes off which would make sense if it is a sensor. Also RHD FTW :D
    I know, and I've got an extra switch to turn on some extra lights in the air vents! I doubt it's the battery as I've been doing some wiring for my new headlights and everything was fine.
    I'll have a look at this, like I said it normally comes on after heavy rain or a proper wash so I'm thinking its dirt running on it, it does go off after restarting the car so it more than likely is the sensor.
    Those look fantastic, never seen halos on there own only in cluster, did you get them off eBay or out of another cluster?
    Also it's my birthday today! Yay!!
  14. rlma84
    rlma84 New Member
    Aug 30, 2015
    6
    Yeah i got them off ebay
  15. Firebro17
    I took DoDo Juice to the paint and Stoner to the glass of my classic. Ready for next weekend's show!
  16. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Cleaned the Justa today. Tried Chemical Guys Carnauba wax. Seems okay, but time will tell. Sprayed off, washed, clay bar, and polish. Time well spent. My wife thinks that I am a little OCD because I use quick detailer on the wiper arms. Time for a drink. :beer
  17. Savvy
    Left it at the off site airport parking garage while I spend the next few days in El Paso.
  18. TheModFather
    Drove the Porker to the paint store, and to get Monster this morning...
    Drove the Rat to Longmont (30 miles each way) to pick up some emergency snowflake stencils from last nights debacle.
    Tomorrow we are taking Erin's R57 up to Aspen for the day!
  19. vetsvette
    My baby got a new pair of shoes. Couldn't stand the Hankook run flats any more.
    Goodyear Eagle F1 Asymmetric All Season 215/45-17
  20. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Today I pulled the MINI and the wife's car into the garage. Big deal because 3 months ago, my side of the garage was a knife making shop...
