  1. MCS02
    Been there brother! Some times its good to go scream, or at least hear that SC scream!
    Washed my car after work and got out the summer wheels. I wiped them down and applied a new glass sealant to them. I will be dropping the car off at a local shop for an oil change, balance my wheels and replace my jacked up Pa state inspection & Emissions stickers because I had my windshield replaced.
    It's getting close to DRAGON TIME! :devil:
  3. MCS02
    Washed your car after work? After the picture you posted? No way! The Dave we know would never do such a shabby job. That was at least two days of washing. If you really did that after work we need to get you to a doctor. :lol::lol::lol:
  4. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Finally installed the R56S front calipers, Pagid rotors, Stoptech pads and lines, and bled out all the old brake fluid for a fresh fill of Motul RBF600.
    Next: Suspension.
  5. mrntd
    Got the new Powerflex front control arm bushings on. Wow were the old ones bad. The car is an '05 with only 45k mi but they were shot. Alignment rack tomorrow.
  6. Jaeger_05
    Jaeger_05 Member
    Dec 30, 2015
    65
    I can't wait to see what mine look like at 160k :spin:
  7. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Glass sealant? What is this wizardry you speak of? Make them glossier and stay clean longer?
  8. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Ordered a new filter for an erl change and bought the Forge charge pipe :) Headed up to WMW (sorry Dave.0, it's local for me) after work to pick up my new MINI swag. I love blowing money apparently :Thumbsup:
    Also, why the hell is oil 30 or so bux for the 5qt jug at autozone and 20 at the wallmarts? I had $40.00 in autozone bux to use up and I used up 38 of it on f'n oil. It's (sort of) free but still.
  9. Jaeger_05
    Jaeger_05 Member
    Dec 30, 2015
    65
    Got the safety and emissions done for registration. Mechanic let me poke around while it was on a lift and there's an oil leak in the back. Most likely cause? Here are some terrible potato pics. It seems to cover the CV boot on the passenger side mostly.
  10. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Crossed another mileage milestone.
  11. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    rear of engine passenger side could be the gasket to the oil heat exchanger or drippings from the last filter change. I had oil some come from the valve cover in that same area.
    If it appears to be creeping across the bottom of the motor coming from the front, then it's either dip stick tube o-ring (most likely) or crank position sensor o-ring, but that's more over to the driver's side.
  12. friendraja
    friendraja Member
    Aug 31, 2015
    System Administrator
    Dublin, ohio
    Back to regular work, doing nothing with coupe:sleep::sleep:
  13. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Changed the oil and added one of these hose thingy's :
  14. Stefanie
    Stefanie Well-Known Member
    May 8, 2014
    545
    804
    Sacramento, CA
    Cleaned off some bird poop.
    Love Spring, but hate all the crap that ends up on the MINI. :frown2:
  15. Jaeger_05
    Jaeger_05 Member
    Dec 30, 2015
    65
    Installed some Osram Rallye's, got the title switched over, registered and ran some errands.
  16. Savvy
    Wa(r)shed it last night after work. And today finally managed a picture next to this....
    Gotta respect the elders.
  17. TheModFather
    Looks like it's in good shape for a Z31.
  18. Nathan
    Drove it...a rare event for me.
    Keep up the good work. It's good for you & your MINI likes it. :yesnod:
  20. Jaeger_05
    Jaeger_05 Member
    Dec 30, 2015
    65
    #12180 Jaeger_05, Apr 14, 2016
    Discovered when i went to put my plates on that the holes don't match on the hatch lid....is there suppose to be some kind of frame or bracket for the license plate? PO just drilled holes in his plate to fit.
    So i ordered one, can't believe they're $35-40! Yeesh.
