  1. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    ok, so they didn't forget the engine mount, but what they let me drive home is difficult to understand: The new PS fan makes hard permanent contact with the top of the Fumoto drain. It is already bent and there is a good amount of oil leaking from the bottom of it. WTF doesn't even begin to describe it. They could have called, I would have gladly paid for a new regular plug as I don't even use it any longer after buying a vacuum oil change pump. The test drove the car and didn't say a thing... Going up my steep driveway, the engine drain slapped so hard against that fan, I thought my suspension was broken again.
    Going to do an oil change (after 1800 miles...) tonight, change the plug, bend that new fan into proper position, as it looks totally out of place, nowhere near the location where the old fan was located, or am I imagining things?
    Hard contact between fan and top of drain
    full install - what's up with that fan at this shallow angle?
    the fresh Mobil 1 is dripping...
  2. BetaMini
    BetaMini New Member
    Aug 2, 2012
    218
    98
    eComm
    New Albany, OH
    Well, I bought a MaxJax for my MINI. Guess that kinda counts. It's an enabler. :)
  3. Red Bull
    Red Bull Active Member
    Aug 9, 2014
    524
    207
    Interesting, I purchase a Fumoto for my FL '05 a few years ago and it had the same clearance problem. At the time, I didn't just want to bend the fan up and just used it on another car. I wondered how so many MINI owners were using one without seeing any posts about it hitting the fan.
    Hidden problems, shortcuts, and unnecessary "test" drives are reasons I don't like to bring any of my cars in for service. :frown5:
  4. cct1
    I didn't do it, but here's what was done to my MINI--by Barry-the past few days...
  5. cct1
    And another...
  6. Firebro17
    Yesterday, we won at Buttonwillow. Not once, but twice!
    Congratulations to my buddy Steve! :beer
  7. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Today I've been tackling some door seam rust I found.
    One more coat to go on the driver's side and passenger side door seams - then I just need to let it set and cure.
  8. mrntd
    I think rust is like car cancer. You got to catch it early and get it removed or it will spread.
    Not to make lite of real cancer for people or pets.
  9. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    Yep.
    This was really minor and minimal, but I didn't want it to become an issue down the road.
  10. DneprDave
    Cool!
    You need a big rubber spider to put in the middle of that cage.
  11. cct1
    It is slightly more robust than my autopower 4 point was.
  12. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I appreciate the brakes on my MINI. Some bonehead ran a stop sign from a sidestreet into traffic. It was his meaning in life to put everybody else in danger just so he could get in front of a MINI.
  13. Dave.0
    :lol:
    Fixed that for you.:devil:
  14. TheModFather
    Don't forget ByteTronik Dave... That one should be second on the list...
    Changed the earl in my little roadster & completed an under car & brake inspection. The brakes look new, I better drive harder. My smoothness is something my brakes like.
    I plan to go over to my buddy's at the local Discount tire for a balance & rotation. My car rides so smooth now. I'm a bit worried it won't be after a new balance. Meotters are very sensitive to wheel balance. What do you guys think?
  16. minirab
    That's impressive!:Thumbsup:
  17. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Added some eye lids and started un-dipping and replacing said dip with vinyl wrap. Headlight rings are done, the rest will be done this weekend. She also gets an alignment this afternoon.
  18. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Where does one get said eye lids? I'm torn on if I like it or not...
  19. TheModFather
    Just use vinyl in your choice of color... Takes like 10 minutes...
  20. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
