    Remember if you drop the clay bar it becomes sandpaper. :smilewinkgrin:
    YUP that's why you only pull off a little bit (1/4) of the bar to use. Never use the whole bar at one time because it is a complete waste.
    Just pull off what you need and go to town and throw it out when you are done. It's only $13 bucks.
  3. bigjas
    bigjas Member
    Sep 3, 2016
    195
    Colorado Springs, CO
    I installed the Helix Short Shifter. The car has been on jack stands since I started last Friday, so I am looking forward to the test drive when I am done with everything.
    The last two things on my list are to install the Craven STDs, and to torque the ATI dampener. I even had my wife push on the brake petal this evening while it was in gear, but the crank is still turning.
    I will not be able to work on it tomorrow evening, so hopefully I can finish up Friday or Saturday.
    Swapped out the summer tires for winters. They are calling for snow this weekend.
    Gosh it feels weirds to drive with squirmy tread.
  5. DneprDave
    Took the summer air out of my tires and filled them with winter air.
  6. Minidave
    I did the same! :biggrin5:
    Nitrogen for mine......
    I bet it does at almost 70 degrees they have to be pretty rollie pollie. You'll be glad you have the winter shoes Sat.
    Hey Dave the air I use has 78% nitrogen. :D
  9. Dave.0
    I had to run some errands today and while I was out I saw a funny bumper sticker.
    It said " Guns kill people like Spoons made Rosie O'Donnell fat." LMFAO :lol::lol::lol::lol::lol::lol:
  10. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    We have a "major" cold front coming through in the next 24 hours. The high tomorrow is supposed to be 62, and it is supposed to get down to 40 tomorrow night. It is also supposed to rain tomorrow -- and with the temperatures that low... I'll need a jacket!
    My MINI will stay on the same tires, but I will need to add some air to them. The average car owner will just run on low air pressure, or wonder what that TPMS warning light means.
    CD
  11. MCS02
    6,328
    Today I ordered a Valeo clutch kit, slave cylinder, Throwout Bearing Guide Tube, rear crank seal, and a brake kit that comes with
    SP Performance Front & Rear Rotors
    Hawk HPS Front & Rear Brake Pads
    Detroit Tuned Stainless Steel Brake Lines
    1 Bottle of ATE typ 200 Brake Fluid
    Already have a tracking number saying it will be here this week end! Thanks Detroit Tuned!
  12. bigjas
    bigjas Member
    Sep 3, 2016
    195
    Someone is going to be busy soon!
  13. MCS02
    6,328
    Yes now if I could just get a day off to get it done. I plan on fixing all the oil leaks, check the timing chain and guides, and fix anything els I can find. It has 151k on it so it is time for a refresh.
  14. MCS02
    6,328
    Just changed the oil in my wife R56, its a very nice MINI. But what brain dead, inbred, moron decided to put the oil filter where it is?? And I guess it takes 4.5 its? because I put almost 5 in and it is too much!:mad2:
    FWIW Lee I always put 5 quarts in Babs clubster, no harm no foul. On a justa there is no turbo in the way. There is not lot of power because of that.
  16. Minidave
    Yep, I always put 5qts in my 2009 Clubman S, still going........
    You're gonna love that Valeo clutch.
  17. MCS02
    6,328
    Thanks guys. It was just past the plactic end. My clutch has been hard to push for some time, now it'slipping. I can't wat to put it in.
  18. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Took advantage of the mid-70's weather, and washed/waxed the Justa. Rinse/dry, Ferrous Dueller, rinse/wash/rinse/dry, Purple Haze Pro. :D
  19. Savvy
    Did an oil change and replaced my fog light housings. The old ones were pretty well f**ked.
  20. Sig
    Sig Member
    Jun 5, 2016
    136
    Oil changed here too. Where's a good place to get a 27mm socket from?
