  1. olerodder
    olerodder Member
    51
    Sold manufacturing automation most of my life, as
    Pacific Northwest
    Yes I will use the run-flats for the winter only. What kind of 17" wheels would you recommend?
  2. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    I have factory 17-inch two-piece wheels that I like, so I haven't changed them.
    Keep weight in mind, and pick wheels that you like the looks of. The lower the unsprung weight, the better your MINI will ride and handle.
    The big problem with run-flats is that they are heavy and hard. With a car as light as a MINI, lighter is better. You can also go with a softer rubber compound on a light car, and still get decent wear.
    I keep a tire plug kit in my car, and figure I can have it towed if I blow one out. To me, that is better than getting beat up daily by run flats.
    CD
  3. 00Mini
    2,262
    I would choose ones that are lighter than the offered stock ones.
  4. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    #13644 caseydog, Jan 11, 2017
    My track car was a Miata, too. I had 15X7 BBS wheels that weighed something like 11 pounds, IIRC. I don't remember the tire size at the moment, but is was the same as the Spec Miata's used at the time.
    I have 215/45 ZR17 tires, which is pretty common among MINI drivers. Mine are Hankook VENTUS S1 NOBLE2 tires. My MINI is a daily driver, so all-weather tires were a more practical choice, and I've been very happy with them. I am also a Michelin fan, but I can't complain about my Hankooks.
    CD
  5. Dave.0
  6. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    I had some OZ Superturismos on one of my Audis. They were 18-something pounds, which isn't bad for a car that size. I liked them. They were definitely high quality. It didn't hurt that Audi used similar looking OZ wheel on the Lemans winning race cars. :cool:
    CD
  7. AAONMS
    AAONMS Well-Known Member
    5,027
    221
    I play with trains...
    Fruit Cove, FL
    olerodder: Welcome to another SCCA guy.
    I was an ITA guy. Most of my time was in a CRX in both first and second generations with a little Formula V thrown in for fun.
    All of those are momentum cars.
    Believe OEM tire size is 205/45-17. Many of us use 215/45-17 as the selection is usually better than 215/40 or 225/40 in 17.
    Currently, believe I'm on my fourth set of Michelin Pilot Super Sports. I see where the tire is being superseded this spring.
    The tire does well here in Florida. On the rare day it gets below freezing, I just have to be cognizant of the temperature and adjust my driving style a little until they warm up.
    Welcome.
    Sent using Tapatalk
  8. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
  9. Chaz
    Chaz Member
    Mar 9, 2015
    35
    21
    I put new wheels on!
  10. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
  11. Chaz
    Chaz Member
    Mar 9, 2015
    35
    21
    that's brilliant!!
    Just put locking wheel bolts on so they can't be stolen easily, and I finally got myself a tow cover for my rear bumper! It's the little things!
  12. Zapski
    I installed a GFBâ„¢ (Go Fast Bits) Diverter Valve today.
    Two observations:
    1- It is much quieter than the OEM one, which is a slight disappointment, but not that big a deal since the old one might have been loud due to all the wasted boost it was letting out.
    2- I never knew how much turbo lag I had until it was reduced by the new valve. Shifting gears under accellleration seems much smoother, much better. There's no power gain but there's a lot less loss. This is a good upgrade.
  13. Metalman
    :Thumbsup:
  14. Zapski
    Today I had the nice men at Best Motor Werks install a Miltek exhaust for me, as the original had a hole at the flex pipe. I got the resonated version, because I'm pushing 50, and it's bad enough I have a red sports car without it waking the neighbors ;)
    Get off my lawn!
    It sounds much better now, deeper and more aggressive.
  15. olerodder
    olerodder Member
    51
    Pacific Northwest
    I just installed the Magnaflow exhaust and the car sounds really mello with a little growl...since I'm over 70 I don't need anything loud. The throttle response seems to be a little better. Next is the AEM CAI and turbo blanket.
  16. mrntd
    Well I drifted it through a rotary. Not on purpose though. Just that the crappy winter tires I have don't stick very well.
  17. DneprDave
    There is a rotary (roundabout) on my way back from town on a road with very little traffic. I used to drift around it on a regular basis, sometime twice.
    Now the area around it has built up and there's too much traffic to do that anymore.
  18. olerodder
    olerodder Member
    51
    Pacific Northwest
    I'm thinking about buying one of the last new sets of MiniLites, the only issue is that they are 16x7 which is almost the same as my old wheels...what do you think?
  19. MCS02
    6,316
    I Like them!
