  1. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Another mileage milestone crossed. Actually did that a few days ago. I wonder if I will cross 300K by the end of next year. That supercharger is starting to sound noisy.
    • Like Like x 3
    • Winner Winner x 1
  2. TATTRAT
    TATTRAT Well-Known Member
    496
    399
    Executive Chef
    NoVA/DC
    Thanks!
    A few odds and ends to get done, grill, side splitters, rear diffuser and interior and it'll be all buttoned up.
  3. TATTRAT
    496
    399
    Executive Chef
    NoVA/DC
    Got the lip on, side splitters, and changed out the DRL turn signal lights to modern LEDs.
    • Like Like x 4
    • Winner Winner x 2
  4. 00Mini
    2,275
    Very sharp and unique !!
  5. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    Drove the front up on Rhino ramps
    and put on some Ultra Racing chassis
    braces on this am. Lower front and lower mid.
    Feels a bit more solid on rough roads
    and a little quicker steering response on
    good roads. You have to take the
    plate under the mid exhaust off to put the
    mid brace’s back 4 bolts on, but it’s much
    more solid than the OEM plate that you
    remove.
    About 2-2.5” tall, but tucked up so
    I’m only losing a little more than an
    inch of ground clearance, and I’m
    not lowered, so no worries there.
    pics are a bit limited as not much room to
    get a good view on ramps.
    4CBF2193-7F21-4EB6-ACC4-878966475026.jpeg E5A5E389-9479-4CF1-9E39-42BE1B6D1C57.jpeg BFB47EA5-7CA0-4CA8-86BC-9258C3CAE20C.jpeg 4E0A14B0-FAAE-4547-BE07-4180E5D4369B.jpeg C56A7D42-E43C-4694-9FE7-9FE40C5655EC.jpeg
    • Like Like x 6
    • Winner Winner x 2
  6. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    Washed it and parked it next to it's big sis:
    Sent from my iPhone using Tapatalk Pro
  7. beken
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Drove the Countryman from Vancouver BC to Vancouver WA today. On the way, met up with another Countryman and we motored together until I turned off at Vancouver WA. We waved at each other.
    So wondering if somebody here drives a BRG F60 Countryman Cooper S, Washington plates BHU5454. I'm the owner of the Lapus Luxury Blue F60 Countryman Cooper S, BC plates SEE-777. Great fun motoring with you.
    Not a favorite brand, but as long as they are the correct heat range & reach they should have been fine. That plug looks good to my eye. Nice healthy engine you have there. The miss could just be down to the age & miles driven on those. I change plugs out at 50K even if some say they last much longer.
    Yes I know some guys run colder plugs & change them more often. :)
  9. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    That one pictured is missing the little pointier part at the top of the electrode, I'll attach a pic of one of the others and you can see the difference in gap. I hope she stays healthy! For a few more years at least... It was almost exactly 50k on the Champion plugs. I need to dig up that service order and see how much I was charged for them. I don't need colder plugs, I'm stock :)
    After 50K they look look pretty good. Nothing screams look out trouble coming. The gap being opened up is normal I'd say.
    Pretty amazing really how long plugs last in these modern cars. Unleaded fuel is a large part I'd guess. Heck when I was young we only got maybe 10K out a set of plugs & I'd pull them at 5K & re-gap them.
    • Like Like x 1
    • Agree Agree x 1
  11. 00Mini
    2,275
    Isn’t that the truth. Plugs, points, rotor, distributor cap, carb adjustments all seem like a distant memory now.
    • Like Like x 2
    • Agree Agree x 1
  12. Minidave
    In the 70's the factory service interval for 911 Porsche plugs was 6K, and they were Bosch Platinums at $6 each - even then! Now engines routinely go 100K on a set of plugs.
    What I did with my MINI today - loaded up a Sprite head and bare block and took them to the machine shop.
    • Like Like x 3
    • Winner Winner x 1
  13. wmwny
    4,040
    2,242
    Today, I'm getting rid of the POS BFGs that are on my S. I'm going back to the Nitto Neo Gens that served me so well when I was tracking my S, going Dragon slaying, and daily driving the car for over
    35k. I guess I had a "Senior Moment" when I went to those BFGs...thinking that a warranted tire was a good tire. Those crappy BFGs were warranted for 35k and ride like run-rocks, are cupping and don't even have 20k on them. Good riddance, BFG!
  14. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #17774 Qik, Oct 30, 2019
    Did you by chance get the Comp 2's? I've had 2 sets on 2 different cars, both ended up cupping. The set I had on my MINI led the guys at the tire shop I USED to use that I had bad struts. They weren't bad, but I replaced them anyway and got some Toyo Proxes Plus 4 AS's. They've been worlds better than the BFG's but it's getting to be time to change them too.
  15. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    My other half is an AP at the high school near my house. I made friends with the auto shop teacher and he let me use a lift for a couple of hours to tinker around my car to find the rattles/clunks I've been hearing. Found nothing in the front aside from my recently replaced tie rod ends clunking when I'd wiggle them up and down. The rears, however, are a different story. The top of the struts where they mount into that upper spring retainer thingy, there are these foam/rubber/plastic bushings. I stuck a bar under each tire and lifted them up and down and there's about maybe an inch of travel. Could the distance between the bottom of the threads on the strut post and the seat below them be longer than OE spec? Thinking I'll need to replace the whole upper assembly to get rid of that travel. Are they supposed to move "freely" up and down about an inch like they are? The circled part in the picture below is where the movement is.
    I know you weren't happy with those BFG tires. Glad you are putting something on that will make you happier. As for the cupping there are a couple of things that can cause that.
    Balance
    Lack of rotations
    Worn out struts
    Your car has a load of miles on it. You probably need new struts. I'd put my money on not frequent enough rotations.
    Enjoy the new tires Jeff. :Thumbsup:
    • Like Like x 3
    • Agree Agree x 1
  17. MCS02
    6,328
    I had that problem with worn out bushings (the yellow things). I replaced them with Powerflex bushings.
    https://www.detroittuned.com/powerflex-rear-shock-bushings/
    I had to reuse the metal peace that runs through the bushings, the one that came with them was to small on the inside for the Koni. Make sure the bolt on top is tight and the two bolts that bolt it to the car are also tight
    • Like Like x 2
    • Agree Agree x 1
  18. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Awesome! I'll replace them bushings. I went with OE spec replacement struts so the metal spacer should be fine. I know all bolts/nuts are tight, I took the passenger side out twice to check when I first installed the struts because there was just a slight wiggle then. The wiggle has since worsened. Thanks for the info bud!
  19. beken
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    #17779 beken, Oct 30, 2019
    Must be car trouble week. Over the weekend, the exhaust manifold heat shield fell off my engine. It was rattling around in the engine bay but did not fall out (thankfully) because the shape it it kept it inside. I managed to put it back on temporarily until I can get a new one. Honestly, I have no idea how to get it out of from behind the engine without removing a bunch of parts. So it's not going to be a simple bolt on affair. This morning, I brought my car in to the local tire shop to have snow tires swapped on. They could not the wheel lock key into the bolts and told me I needed to take my car to the dealer to get them off and then replace the locking wheel bolts because, from their experience, all the MINI/BMW lock bolts eventually fail like that.
    I stopped by the dealer that was on my way to my office. They didn't have any bolts in stock. (really???). They do have them at the dealership not too far from my office so I will pick them up later and do the tire change over myself when I get home tonight. The dealer was booked full for service appointments today already.
    I've had nothing but problems with locking lug bolts/nuts. First thing I do with a car is replace them if it has those blasted things. I have 4 from the GTI if you need them. ;)
