  1. wmwny
    4,040
    2,242
    Thanks! I never expected the freebie, and I wanted to tip the guy [extra] when I got the bill for the second job. He's a biker and I told him all about the Dragon and the surrounding roads. He said, "no charge" for the first, because he felt the info I had given him about the other roads down there was worth it and will extend the time that he and his buddies are down there in the future.
  2. agranger
    I was sitting at my favorite breakfast diner with my wife many years back (Dallas, TX). There were 2 bikers in the table next to us, planning their route. They were down from Canada for a conference of some sort and were taking a few weeks to see the US. They were plotting their way to the Dragon. I helped 'em choose the right highway (there are 2 routes from Dallas... one about 40 miles longer but MUCH smoother than the other) and then started asking them how twisty they wanted to go. I routed 'em in across the Cherohala Skyway, provisioning in Robbinsville and on to Fontana w/ a few days worth of roads and Dragon riding. We must have sat there for 30-45 minutes, going through the roads. I got an email and photos from them when they got home a few weeks later. Bikers and MINIs have the same taste in roads! :D
    I met a father-son team who were on the son's post-college-bonding-trip-with-his-old-man at the brake cool-down lot on the west side of the Dragon. I think that they were out of Boston. I had an early camera set-up on the tow hook mounting points, so I got video of them (both in front of and behind me) driving the Dragon and sent them links when I got home. Those guys went CRAZY watching that footage and sending me links to their favorite bits for days (and ragging on each other for crossing the yellow).
  3. checkers
    checkers Well-Known Member
    Jun 11, 2009
    4,419
    1,002
    Modesto, Ca
    I would love to go someday, but I'm to old and it's just to far to go unless I hit the lottery. Then I could send me and the car air freight.
    • Like Like x 2
    • Funny Funny x 1
  4. 00Mini
    You could go by train like in Italian Job. :)
  5. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    #19565 cristo, Mar 14, 2022
    Changing the turbo oil feed line
    (Detroit Tuned) and oil filter/cooler/housing.
    One of the turbo to down pipe studs
    snapped a couple mm into the turbo so that
    will be fun to deal with.
    I’m to the point of trying to extract
    (that trick never works [Rocket J Squirrel])
    or drilling and tapping through the screw
    or, if that doesn’t work due to the hardness
    of the stud fragment, maybe an adjacent hole.
    The oil filter cooler housing is back in
    with new gaskets. So is the turbo line.
    Lots of fun with all that, too.
    I’m getting too old for this stuff.
  6. MCS02
    Oh no! That is not fun!
  7. 00Mini
    I feel your pain on trying to drill out broken bolts/studs as I never had a real good success rate but then again I didn’t have the best equipment for the job.
  8. Metalman
    Not an insurmountable problem...... If....
    You can pull the turbo back off and take it to a capable Tig welder (not Mig welder)....
    We would have this taken care of in 15 minutes in my metal shop....
    We would lay a hex nut over the broken stud / bolt and add weld down through the threaded hole in the nut with the weld puddle on top of the broken stud / bolt.... The combination of the weld temperature would loosen the threads and the use of a socket or box wrench would allow you to back the stud out.... Those brittle EZ Out screw extractors never worked for me..... And if they snapped off.... You're in more trouble....
    Clean out the threaded hole with a tap before going at it again with the new stud / bolt.
    Good luck...
  9. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    #19569 cristo, Mar 15, 2022
    Got ‘er done, mainly.
    Took all of yesterday (Monday) and half of
    Sunday and half of today.
    This is a staycation week for me.
    Drilled through the bolt (actually mostly
    just outside of the bolt as I had a very
    hard time keeping the hole centered on the bolt, then tapped the hole and put a new
    stud in (that took a good part of this am).
    A 90 degree drill adapter was crucial for this
    since I didn’t put it in service mode and
    spacing was too tight for a drill otherwise.
    Got it all together (except for the front upper
    and lower heat shields and the top oxygen
    sensor bracket to the tensioner) and refilled
    and bled the coolant and topped off the oil
    and it appears to be running soundly without
    leaks or new noises or codes.
    Still have a bunch of tools to sort and put
    away, but none of the remaining stuff is urgent.
    When I was done, someone had parked less
    then 2 feet behind me, and I have 3 foot 2-piece
    Race Ramps, so just when I figured I could
    back up a little more then halfway down, set the
    Ebrake hard, and use reverse to slide the
    ramps forward out from under me (hold my beer
    and watch this), he left.
  10. 00Mini
    Gotta love it when a plan comes together !! :Thumbsup::Thumbsup:
  11. MCS02
    No Mini action to report. I just ordered a stand alone ECU for my Exige. Tomorrow I will start a thread about it for anyone interested. It’s a ECU Masters Black ECU. they make one for the R53 also. I have never tuned an ECU so this should be fun.
  12. 00Mini
    Good luck on your quest. Being extremely computer challenged I would never attempt to do something like that.
    • Like Like x 1
    • Agree Agree x 1
  13. 00Mini
    Went for a nice drive while enjoying the beautiful spring like weather.
    • Like Like x 2
    • Agree Agree x 1
    • Winner Winner x 1
  14. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Close! It was the tube from the Jarvic 7 going to the water pump, it was leaking at the pump side. They did put in a new Jarvic 7 though, figure it's good insurance while they had the old one off anyways. Only down/upside to my shop only using OEM parts is the cost of those damn things. She's back on the road though, good as newish. And this was her 4th or 5th time on a flatbed... lol! Owned her since 34k, at 157k at the moment.
  15. 00Mini
    Good to hear everything went well and you’re back on the road …. even it is with a thinner wallet. :):Thumbsup:
  16. cristo
    Jan 4, 2015
    5,713
    924
    physician
    York, Pa
    :D:D
    Finally got a couple hours free and put the lower front and upper heat shields back on
    as well as the upper O2 sensor bracket.
    It’s all done now except sorting and stowing
    all the tools.
    :D
  17. 00Mini
  18. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    My MINI has been sitting in the garage. I can't figure out what's up with the cooling system. My best guess is the thermostat is toast. It got a new water pump when I did the timing chain service.
    I am sending it down to my friend Hans at AutoScope to have it fixed, and get an oil change. Then, I'm selling it. I just don't drive it enough, and that is going to keep causing problems like my current cooling problem.
    I will offer it first to members here. So, if you have an interest in a really nice 2007 MCS with 118,000 miles, let me know. It is a very nice car, with low mileage for its age -- less than 8,000 miles per year. Of course, it has been garage kept -- my cars don't stay outside when at home, period. Not many luxury options, but good performance options, including LSD.
    I'll list it on the "for sale" forum later, but you can PM me if you are interested.
    I love that car, but it needs to be driven more than once a month, or things are just going to keep going wrong with it.
    CD
  19. MCS02
    Good luck on the sale but I do hate to see you sale it but I understand.
  20. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Yeah, I hate to let it go, but I have so many clients who have car collections, and most of the cars don't get driven enough. Those cars are constantly having problems. I'm pretty sure that AutoScope is going to find that my thermostat has stopped working -- because the car sat for too long. When I was driving the car almost daily, I rarely had anything go wrong. Cars are meant to be driven.
    CD
    • Like Like x 2
    • Agree Agree x 1
